| need advice on rear universal joint removal https://slantsix.org/forum/viewtopic.php?t=10620 |
| Author: | gmader [ Sun Oct 10, 2004 1:35 pm ] |
| Post subject: | need advice on rear universal joint removal |
Hi all, I have removed the driveshaft from the rear axle ( orginal 7.25). That was easy. How do I remove the U-Joint from the driveshaft now? I have sprayed it down with parts cleaner, and it does not appear to have any C-clips on the inside of the cups for the U-Joint, although there are grooves. I have a large pipe nipple on one side, and the biggest C-Clamp I own pushing it from the other. No movement. So, what am I doing wrong? Are there C-Clips that I cannot see on this beast? More force? What gives? Thanks, Greg |
| Author: | 70valiant [ Sun Oct 10, 2004 3:18 pm ] |
Look more closely for the C-clips if they aren't there the caps will slide out pretty easily with a C-clamp. |
| Author: | gmader [ Sun Oct 10, 2004 7:10 pm ] |
| Post subject: | c-clips removed, still not moving |
Hi all, Okay, i cleaned it more thoroughly, and found the c-clips. The C-Clamp still cannot budge this thing. What next? Heat? Better C-Clamp? vise? Thanks, Greg |
| Author: | gmader [ Sun Oct 10, 2004 7:26 pm ] |
| Post subject: | Update: I broke a bench vise. |
Hi all, Okay, I thought I would bring out the heavy artillery. I used my grandfather's bench vise, ( I had inhereted it this spring), and use the pipe nipple with that to squeeze the U-joint. Nope, I broke the bench vise. I might try to post pictures tomorrow. Right now, I feel like crawling under a rock, and hiding. I really could use any advise that anybody has. I am shipping out to a country that begins with the letter "I" later this week, and I would like to get this done before I leave. Thanks, Greg |
| Author: | Pierre [ Sun Oct 10, 2004 9:18 pm ] |
I used a hammer and socket. I had a helper hold the shaft for me over the vice, so the jaws of the vice were just wider then the cup, and then used the socket/hammer to tap the cup facing up. Unless you forgot a clip or the cups are frozen in place, you should have your joints swapped within a couple of minutes using this method. |
| Author: | Reed [ Sun Oct 10, 2004 9:37 pm ] |
You broke bench vise?!?!? I have always had success using a 9 inch c-clamp and one socket (from a ratchet wrench set) smaller than the diameter of the u-joint and one socket larger than the diameter of the u-joint. Press the joint into the larger socket and it should slide out. Of course, it takes some effort, and I have bent the threaded screw-shaft on my c-clamp, but it works for me. Try taking it to your local machine shop if all else fails. |
| Author: | VDART [ Mon Oct 11, 2004 4:26 am ] |
| Post subject: | u-joint |
I 2nd'' hammer- socket style, make sure the clips are removed & hammer away, should come right out. |
| Author: | 70survivor [ Mon Oct 11, 2004 5:36 pm ] |
Are you sure the C clips are removed? I have had better luck with a hammer and socket insted of a vise. From experience, I cracked a U-joint cap using a vise and there was no needle laid over in the cap. Just keep in mind not to lose your cool while performing this exercise. |
| Author: | Pierre [ Mon Oct 11, 2004 9:00 pm ] |
If the hammer method doesn't work and you don't want to take it to someone, it just may be less headache to make two cuts with a cutting wheel and grinder or hacksaw and pull the center of the joint out, should make tapping the cups out easier. |
| Author: | guest [ Fri Nov 12, 2004 6:49 pm ] |
| Post subject: | c-clips |
if you cannot get those c-clips out, try using two flatheads, find the opening if the C, and put yout blade on each edge, use one to hold, and one to pound out. I had the same prob, that was the only solution |
| Author: | gmader [ Sat Nov 13, 2004 12:05 am ] |
| Post subject: | Sorry, should have reported the solution |
I figured it out before I left home for Baghdad. I used Pierre's idea, and cut the universal joint below the cap on both sides, and popped each cap out with a C-Clamp. This way I only had to press one out at a time, not two. Thank you, Rotozip with 90 degree cutting wheel. Best money I have spent on a tool, short of a cordless drill. Greg |
