| p/s..to..manual conversion https://slantsix.org/forum/viewtopic.php?t=10633 |
| Author: | mightyss [ Tue Oct 12, 2004 2:23 pm ] |
| Post subject: | p/s..to..manual conversion |
switching from p/s to manual in my 63 valiant. other than a manual column and box, is there anything thing else i need to change?? how bout pittman arm will it bolt to manual box?? thnx,,,,,,,,,,,,,steve |
| Author: | relic-lover [ Tue Oct 12, 2004 9:00 pm ] |
The suspension catalog for RareParts only lists one pitman arm for 63-66. I interpret that to mean the power steering and manual steering arms are the same one. Check out the belt configuration for the power steering pump - you might need idler pulleys or some brackets to change the belt geometry to get rid of the pump if it shares the belt with another accessory. |
| Author: | mightyss [ Thu Oct 14, 2004 1:10 pm ] |
| Post subject: | swap |
relic-lover, thnx for the info on the pitman arm, good news for sure. as far as the pulleys, there are 2 crank pulley grooves. so eliminating p/s just leaves an empty groove. i would like to only have a single groove pulley though.....steve |
