It is currently Wed Jul 15, 2026 1:53 pm
 Post subject: seeping oil
PostPosted: Wed Aug 18, 2004 9:25 am
SSRN National Champion
i have a slant six engine that is seeping small amounts of oil between the block and head. could this mean i need to re-tourque the head. the engine has a copper head gasket.
PostPosted: Wed Aug 18, 2004 10:10 am
Are you sure the oil isn't coming from the Valve cover gasket?
PostPosted: Wed Aug 18, 2004 10:31 am
If it's near the front, it could be the alternator bracket hole (if your bracket's gone), which is open to the outside.
PostPosted: Wed Nov 03, 2004 6:31 am
i get the oil seeping too and have no idea were it goes from. never knew about a alternator bracket hole. mine looks to be leak between the block and head
this is my first toy i thought i was gona go bigger untill i taalk to a few slant six fans
PostPosted: Wed Nov 03, 2004 7:16 am
What type of sealant did you use on the gasket? Where did you put it?
Tom
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
 Post subject: Re: seeping oil
PostPosted: Wed Nov 03, 2004 5:41 pm
Oh yeah, copper head gaskets are known to weep. Retorque the head.
Mitch
 Post subject: been in the mess
PostPosted: Sat Nov 06, 2004 10:10 am
i have found leaks from the timing cover seal. fuel pump gasket, oil pump gasket, and the various bolts that tap into the motor before, all were decieving.
anything worth doing is worth re-doing, again and again and again...........
