valiant rear end
https://slantsix.org/forum/viewtopic.php?t=10822
Page 1 of 1
Author:  andrew5266 [ Fri Nov 05, 2004 12:18 am ]
Post subject:  valiant rear end
aloha all just started on a project , putting a blower in a 71 valiant so i want to make sure the rear end goes in a sraight line ? can anyone tell me how to work out what the rear end is , i think plymouth called it sure grip ? how do i find out what size the end is and if it is posi ?
hope someone can help , im just in the process of building the blower manifold and hooking up a double pumper 650 holley , should turn some heads !!!!!!!!!!
my e-mail is popea001 @hawaii.rr.com , hope someone can help me and me island car
Author:  Doctor Dodge [ Fri Nov 05, 2004 8:06 am ]
Inspect the rearend to see if it has a rear cover or if there is a gear "carrier" that bolts-in fron the front.
If it has a cover on the back of the housing (most likely) then count the number of bolts, there should be 9. The most common rearend in a SL6 powered 71 Valiant is a 7 1/4. (ring gear size)
To check for a Sure Grip (Posi) jack the car up so both rear wheels are in the air and spin the rear wheels by hand, a Sure Grip will make both tires spin in the same direction. With the engine off and in "Park", e-brake off, if you spin the rear tires and they go in opposit directions, it's an "open" rear end.
Author:  andrew5266 [ Sun Nov 07, 2004 12:15 am ]
Post subject:  rear end
aloha DD thanks for that armed with trolley jack im off to the garage to see what happens mahalo Andrew5266 :?
Author:  guest [ Fri Nov 12, 2004 6:34 pm ]
Post subject:  weak
they dont have posi for 7-1/4 do they? so would it be cheaper to rebuild a 7-1/4 or try and find a decent beast 8(dont remember size)
Author:  70valiant [ Sat Nov 13, 2004 4:54 am ]
IMHO it would be a waste of time and money to rebuild a 7 1/4" rear if you are going to be putting that kind of power to it, even with a suregrip that ring gear is still small. find your self a nice 8 1/4 or better yet 8 3/4 and rebuild that. It will hold up MUCH better and an 8 3/4 makes gear swaping much easier.
