| Got discs ... now what? https://slantsix.org/forum/viewtopic.php?t=10853 |
| Author: | sixty4dartgt [ Mon Nov 08, 2004 10:27 pm ] |
| Post subject: | Got discs ... now what? |
OK I have the front discs, spindles, etc. from a '74 Valiant. Now what? I have an idea of how to put it on. Here are my questions: 1. When ordering a front end rebuild kit, can I order a '74 or do I need some '74 and some '64? 2. What parts need to be "pressed" in? Can I take the parts somewhere and then install them? 3. What tools do I need for removal of old items? 4. Do I need a adjustable proportion valve or will a new '74 do? 5. Is it a waste of time to just bolt everything on and see what needs replacing? Thanks a bunch for helping me out! |
| Author: | '74 Sport [ Tue Nov 09, 2004 6:48 am ] |
| Post subject: | A picture is worth a thousand questions |
First things first... Do you have a good repair manual? I would not even consider starting the project you are facing, until I got at least a Haynes Repair Manual for your car's body type. It was a great resource for the front suspension rebuild I did recently on a '74 Dart Sport for my son (my first time I might add). Jerry |
| Author: | GTS225 [ Tue Nov 09, 2004 3:08 pm ] |
OK.....That's great that you have those brake parts, but......Do you also have the matching upper control arms? The UCA's are also required pieces in order to put late model brakes on an earlier model A-body. Roger |
| Author: | Guest [ Tue Nov 09, 2004 3:58 pm ] |
Unless you recently rebuilt your suspension it would be stupid not to replace all the bushing, I did a disc brake conversion on a 73 Dart and replaced every bushing because I was there. Most places that would press out bushing do it for a very reasonable price(I had connections and got it done for five bucks, but you can expect to pay more Oh, and the manual is very necessary, I hate my haynes manual but even so without it I'm fairly sure I wouln't have been able to do the suspension rebuild/swap. You might also take this time to seriousely think about upgraded torsion bars, bigger ones will help handling a ton(I'm using .99, but most people for street seem to prefer .86-.92) -Shivadart |
| Author: | relic-lover [ Tue Nov 09, 2004 7:43 pm ] |
| Post subject: | front end rebuild and disc conversion |
Quote: OK I have the front discs, spindles, etc. from a '74 Valiant.
etc includes a master cylinder for disc brakes, right?
Quote: 1. When ordering a front end rebuild kit, can I order a '74 or do I need some '74 and some '64?
When you rebuild the front end after (or during) the disc conversion you would use the 74 partsexcept the strut rod bushings and LCA bushing would still be 64. And those parts are the same for 62 to 76 ! So you use all 74 parts for a disc brake front end! Quote: 2. What parts need to be "pressed" in? Can I take the parts somewhere and then install them?
If you rebuild the entire front end the LCA bushing and the UCA bushings on each side need tobe pressed in. Sometimes a bench vise is enough - but on my LCAs I almost broke my vise and then used an arbor press to finish the job. Removal of the LCA bushing is also easier with a press. It will save you quite abit of time if you have someone else remove and replace all the UCA and LCA bushings. Quote: 3. What tools do I need for removal of old items?
Very handy special tools for this job are a ball joint socket to replace the upper ball joint in the 74 UCA. Also a tierod end splitter of the type that preserves the grease boots and can fit in the space to split both the tie rods and the ball joints. A 74 shop manual will be a big help. Quote: 4. Do I need a adjustable proportion valve or will a new '74 do? Either should be fine.
Quote: 5. Is it a waste of time to just bolt everything on and see what needs replacing?
Used brake and suspension parts are a big risk to life, limb and vehicle if theyare in bad shape. Check everything and make sure is is in sound condition and installed correctly. Rebuild all used calipers and master cylinders, Replace all flexible brake lines with new, get the rotors turned, check all suspension parts and if in doubt replace with new. I recommend the do it right plan instead of the do it again plan. |
| Author: | sixty4dartgt [ Wed Nov 10, 2004 7:21 am ] |
Thanks for the help. I do have the UCA's. I have a '67 Dart shop manual. Do I need a '74 manual also? When you say rebuild the calipers, you mean buy rebuilt? |
| Author: | '74 Sport [ Wed Nov 10, 2004 8:28 am ] |
The "sliding style" calipers from the '76 Duster disc brakes I swapped were easy to rebuild. I bought new seals at O'Reilly Auto Parts for about $2.29 each. If you have a repair manual, it will show you how to do it. One thing you need to look for is whether the caliper's piston is rusty. Mine had a small amount, about the size of a pencil eraser, so I used some very fine sandpaper to polish it out. You may also need to hone the cylinder, if it has any surface rust. If it is pitted, I would buy another one. The book shows how to use an air compressor to pop out the pistons, but beware, you can lose a finger if you aren't careful. Jerry |
| Author: | 65 dartman [ Wed Nov 10, 2004 4:29 pm ] |
Rebuilt calipers and brand new rotors, pads and hoses will make the job simpler and should be safe as well |
| Author: | relic-lover [ Wed Nov 10, 2004 7:56 pm ] |
| Post subject: | more ... |
Yes I said rebuild them - but buying them remanufactured is good also. The point was NOT to trust a used caliper because the risk is too great. The 74 manual I recommend for the disc brake section - The 67 manual will have a disc brake section but it will be regarding the Kelsey Hayes setup used from 66 to 72. These are not quite the same, so a 74 manual should give procedures and specs for the sliding caliper discs used on the 73-76 cars |
