| manifold gasket? https://slantsix.org/forum/viewtopic.php?t=10859 |
| Author: | zedpapa [ Tue Nov 09, 2004 12:08 pm ] |
| Post subject: | manifold gasket? |
I have ad my manifolds off twice now to replace the manifold gasket. right now i have the clifford duals and the stock intake on the motor. the last two gaskets were felpro. which gasket can i use to keep this from happening again? i think there are least four cylinders leaking right now. and the collector gaskets are pretty much gone too, so i will have to replace those as well. thanks for the sugestions. zedpapa |
| Author: | Doctor Dodge [ Tue Nov 09, 2004 9:21 pm ] |
Both Clifford and the Cox boys have a thicker material I/E gasket for the SL6 Also check the header flange for flatness, it may be bent / bowed to the point were nothing will seal. DD |
