It is currently Mon Nov 30, 2026 7:30 am
 Post subject: AC Bracket question
PostPosted: Sun Nov 28, 2004 10:38 am
I'm reassembling my '74 Plymouth Scamp with factory AC and I have 3 tubular brackets that support the compressor. I cannot remember where they go. Does anyone have a picture of this setup? I got the main steel massive bracket on the three water pump bolts but these tubular brackets go underneath or on the back and I believe they connect on the power steering pump bolts somehow. The ac side I believe they connect to the bolts that connect the compressor to the massive front bracket. Any help would be appreciated. BTW there are three of these tubular brackets.
Thanks
Sweet Emotion
PostPosted: Sun Nov 28, 2004 5:48 pm
...one goes to the motor mount bracket, one goes to the intake under the carb, and the top one angles over to the head.
D/W
If it ain't broke, fix it!
PostPosted: Tue Nov 30, 2004 11:26 am
Thanks Dennis I got em hooked up last night. One problem I had was the new motor mount didn't have the hole for the bracket. I looked at the old MM bracket and it did. So I pulled the new one off the engine and drilled the hole. Also it took some head scratching to find the right mounting hole in the AC unit but the info you gave me helped a great deal. Thanks again. I'll post pics when I get it all together.
Sweet Emotion
PostPosted: Tue Nov 30, 2004 3:12 pm
You're welcome. I couldn't recall from memory where they went on the compressor myself! I tried to find a pic to post for you, but didn't have a good one handy - glad it got you looking in the right direction, though.
D/W
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
