It is currently Sat Jul 18, 2026 9:28 am
PostPosted: Fri Jul 21, 2006 8:24 pm
Ok, Im reading up on the hyper-pak slant six and am curious about it.
I read that it was factory rated at around 195 hp? But I have also read that it was HIGHLY underrated. What were the cam specs of the hyper-pak engine? Is there a hyperpak cam available? Was there a 170 and 225 version of this engine? Anything else special to the hyper-pak engine??
Did the hyperpak have a special head developed for it??? :D :shock:
PostPosted: Fri Jul 21, 2006 9:06 pm
There actually were no factory Hyper Pak motors. It was a kit you bought from the dealer. IIRC, it was intake & exhaust manifolds, carb, cam and springs, and some say 4.88 gears.
The NASCAR cars were all 170 motors.
PostPosted: Fri Jul 21, 2006 9:12 pm
I heard it also came with special domed pistions to jump the compression up to 10.5 without shaving the head. It still used those tiny stock valves though. I think it also included a tweaked distributor.
82 D150-225/727
02 Dakota-3.9/5 speed
