| Disc Brake Setup Prices https://slantsix.org/forum/viewtopic.php?t=10912 |
| Author: | 73dart_swinger [ Tue Nov 16, 2004 2:27 pm ] |
| Post subject: | Disc Brake Setup Prices |
how much would a front disc brake set up run you guys in yall areas? it seems that the people and junkyards that know what they have want $400 or more. im having trouble finding a set up but found a car with disc brakes and a blown motor. so i might be able to get the whole car for pretty cheap. |
| Author: | Pierre [ Tue Nov 16, 2004 2:45 pm ] |
Thats insane... I wouldn't pay more then $150 around here (upper arms, spindles, calipers/rotors both sides) at a junkyard. Remember you don't need everything, lots of parts are still availible new/rebuilt. The only key items are the upper control arms and spindles. If you want to save some bucks and get junkyard rotors buy them with a return policy at least so you can have them turned/measured to make sure they are still in spec before installing. |
| Author: | 70valiant [ Tue Nov 16, 2004 5:02 pm ] |
That is about going rate for small bolt disk brakes(maybe a little high, they get $350 around here) I agree with Pierre if they are big bolt though. |
| Author: | Pierre [ Tue Nov 16, 2004 6:01 pm ] |
The pick n'pulls here don't care, big bolt small bolt they don't differentiate. The only thing they ask you is from what make and if its a car or truck. Usually truck stuff is a bit more but not by much. A rear end is $60, wether a dana 60 or a 7 1/4. They are a chain, not a ma n'pa local type of thing. I doubt the workers would know the difference in market value of a 78 Volare or a 69 Barracuda. Man if I could sell every disc brake setup I find for $400..... |
