| Broken Leaf spring 1987 D150 truck https://slantsix.org/forum/viewtopic.php?t=10937 |
| Author: | Craig [ Thu Nov 18, 2004 9:25 pm ] |
| Post subject: | Broken Leaf spring 1987 D150 truck |
Anyone have experience with leaf spring sources? I'll probably opt for salvage yard springs .... IF they have anything better than mine but here in the rust belt the salvage yard stuff aint great.
| Author: | Pierre [ Thu Nov 18, 2004 9:56 pm ] |
www.espo.com They have a great reputation. Not sure if they do truck stuff tho, but I'd start there first. |
| Author: | Super6 [ Fri Nov 19, 2004 12:25 am ] |
| Author: | Eric W [ Fri Nov 19, 2004 1:21 am ] |
Quote: |
| Author: | Craig [ Fri Nov 19, 2004 11:03 am ] |
Well, I almost have the problem solved. Went to local salvage yard and all the trucks were missing the springs, So I bought the whole frame with rear springs and front suspension for $250 + sales tax. Is that a good buy or not? They will remove the all the other parts from the frame and let me know when it is ready for me. Now next spring I can swap all my good parts over to the nice frame. |
| Author: | Super6 [ Fri Nov 19, 2004 11:20 am ] |
$250 for a good chassis sounds like a screaming deal to me. For new springs, check out: JCWhitney I am still trying to figure out how the painted sheet metal fared so much better than the undercoated (at some point) frame/chassis.... -S/6 |
| Author: | Craig [ Fri Nov 19, 2004 8:20 pm ] |
Hey S/6, I was wondering when someone was going to notice and ask about that! The original box got quite rusty some years ago and I happened upon a rust free box at an auction for $25.00, yes only $25. It had both rear corners below the tail lights smashed in but that was a whole lot better than my rusted through box with both sides flopping around and ready to fall apart. Now here's the really good part.... some kid ran a stop sign before I swapped on the new box and plowed into the side of the old rusty box. Their generous insurance company paid me $400 more than I had originally paid for the truck in the first place. Anyway, that helped pay a body guy to patch up the bent corners on the "new" box and repaint it to match the rest of the truck. Hey, aren't you the guy who was going to mail me the ESA module from your 87 truck? Yes, I just browsed JCWhitney last evening and see they had springs for $90 each. -Craig- |
| Author: | Super6 [ Sat Nov 20, 2004 2:58 am ] |
Quote: Hey, aren't you the guy who was going to mail me the ESA module from your 87 truck?
Yep. Do you need the electrical connectors? The entire harness is no longer complete, but I can salvage the connectors with ~one foot of wire for each pin for easy splicing. The VSS is frozen on the lower speedo cable. Kroil didn't even make it budge. PM me your address and I should be able to get the computer, VSS & lower cable, and connectors (if needed) out this weekend. -S/6 |
