| engine braking https://slantsix.org/forum/viewtopic.php?t=10951 |
| Author: | guest [ Fri Nov 19, 2004 7:55 pm ] |
| Post subject: | engine braking |
is engine braking a lot on a auto bad for it? what about shifting back up on a hill to get in third gear? |
| Author: | Dennis Weaver [ Sat Nov 27, 2004 6:57 am ] |
I engine brake just about everything I own (second, not usually first, though). This really helps if you've got the 9" binders. I've been doing this for over 20 years with various Chrysler and AMC (904 equipped also) products, and I've never burned up a trans. The only cars I've owned that I had to build transmissions for were screwed up when I got 'em, or beefed up for performance. My Duster had 245,000 miles on the original transmixer which was still shifting fine, I freshened it up when I hopped up the six as a matter of course and swapped in a low gearset. I can't give you the overall big picture whether engine braking with an auto is good or bad, but my experience is that it has had no ill effects, and is very helpful to my driving style. I usually keep the trans in 2 range for city driving until I've built up a good head of steam and do the 2-3 change manually. This way I don't have to wait around for the kickdown if I need the power to dust off some slug... D/W |
| Author: | Doctor Dodge [ Sat Nov 27, 2004 8:36 am ] |
| Post subject: | Re: engine braking |
Quote: Is engine braking a lot on a auto bad for it? what about shifting back up on a down hill, to get back into third gear?
I never had any problems with doing this. The factory survice manual also says it is Ok to use lower gears on steep downhills.The only thing special I do is to get back into the throttle while in second, before I upshift into Drive. Doing that seems to help soften the upshift so the U-joints / rearend don't "clank" with the upshift. DD |
