It is currently Mon Nov 30, 2026 3:16 pm
PostPosted: Wed Nov 24, 2004 2:02 pm
Hello,
I am getting the block decked.100" and the head is milled the same amount - will be using an older felpro head gasket - same thickness as the chrysler steel one .020"
My question is Do I need to have the head bolt holes tapped further?
I would like to go with the arp Studs, but money dosent grow on trees.
Thanks for any and all Help.
Greg Ondayko
69 Dart Slant 6 4 Bbl 4 Speed
www.geocities.com/gao5498/slant6.html
PostPosted: Wed Nov 24, 2004 2:48 pm
Use hardened steel washers under the bolts.
Mitch
PostPosted: Wed Nov 24, 2004 7:21 pm
It is a good idea to run a 7 / 16 - 14 unc bottoming tap thru all the head bolt holes. I do that on all my rebuilds, just to be sure the threads are clean.
The bottoming tap will take some material out on the last few turns and that is OK.
Blow-out all the chips when you are finished.
PostPosted: Thu Nov 25, 2004 9:41 pm
BTW, if it's not been done already, you should chamfer the top of the bolt holes on the block.
Steve
 Post subject: My options
PostPosted: Sat Nov 27, 2004 7:30 pm
OK, so I can chase the threads with a bottoming tap; But if I do this this will I still need to use the hardended steel washers?
Thanks,
Greg Ondayko
PostPosted: Sat Nov 27, 2004 9:12 pm
Ya checking out the performance articles in the articles section they suggest a mopar hardened washer for removing material off the off the head of block.
Do you mean you milled .2 off total or .1 off total?
PostPosted: Sun Nov 28, 2004 4:59 am
It would be .200" total
.100 off head + .100 off block.
Maybe the arp studs would be easier - Does anyone know about how much a set of head studs and bolts would be - Price? and who supplies them?
Again just weighing my options.
