It is currently Mon Nov 30, 2026 12:53 pm
 Post subject: junkyard logblock help!
PostPosted: Sun Nov 28, 2004 1:57 am
i saw a 64 dart in the junkyard today. i was hunting around for a decent longblock for my 64 dart. the car looked like it got hit in the right front panel pretty good but the engine looked fine. i pulled the head off of the junkyard car and noticed that it had a hydraulic cam. i think the engine was not original. i also noticed that it had a bent rod. would the bent rod effect the long block in any way? also will my original 64 head work with a hydralic cam?
also ... i noticed on the junkyard car that when someone took the flywheel off that they managed to bend a corner of the mounting plate(i dont know the technical term for that :( )i havent had time to check my old block to see if this was replaceable. do you guys know? what should i look for to tell if this engine is good? thanks for all of your help.
BOb
PostPosted: Sun Nov 28, 2004 9:33 am
Junkyard engines are a real "crap shoot', you never really know what you are getting.
Did you just pull the valve cover off, or did you pull the cylinder head off the engine?
Can you get us a picture of the bent part, I am not clear on what part you are discribing.
The best way to check-out a junkyard engine is to get a battery and some gas and start it up before you take it out of the car.
PostPosted: Sun Nov 28, 2004 6:21 pm
i pulled the valve cover gasket off first and it looked really clean. the gasket was brand new,so i figured i might as well pull the head off. the piston cylider walls looked to be in good condition and the head gasket was new also. the bent part is where the flywheel bolts to the motor. it has four bolt holes in it.
 Post subject: Bent rod--ouch
PostPosted: Sun Nov 28, 2004 7:05 pm
Car Model: '63 Dart GT Convertible
I suppose on some engines a bent rod would be bad, but if you are talking about a pushrod,I know that my 71 truck runs fine with the one it's got. I guess I never had time to pull it uot and take a hammer to it. No,No,No really I'm not kidding.My truck has been that way for at least 7 yrs.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Sun Nov 28, 2004 7:33 pm
Was this an automatic trans car? It sounds like you could be describing the flex plate where the torque converter would bolt on, but I'm not that familiar with /6 torque converters, either.
PostPosted: Sun Nov 28, 2004 8:16 pm
its the tourqe converter not the flywheel. sorry im new to engine repair. the flex plate is bent in one corner
 Post subject: flex plate
PostPosted: Sun Nov 28, 2004 8:34 pm
The flex plate can be replaced. Hope it all works out great for you.
dave
PostPosted: Sun Nov 28, 2004 9:54 pm
So, it sounds like the cylinder head may have been recently reworked.
Does the head look clean or does it have a different paint color then the engine block?
May be the whole engine was rebuilt recently, that would be cool.
The bent push rod could be the result of a stuck or tight valve guide.
One test is to tap the tops of the valves / rocker arms with a hammer, they should open and snap shut with a distinct sound. A stuck or tight valve guide will not snap shut, it will just go "thud" when you hit it.
