| Need help with idle adjustment https://slantsix.org/forum/viewtopic.php?t=11043 |
| Author: | 74360scamp [ Sun Nov 28, 2004 7:11 pm ] |
| Post subject: | Need help with idle adjustment |
1974 Scamp with 225. I can't get it to idle high enough to keep running when I put it into drive (auto). From what I can see, the carb only has a fast idle adjustment (for the choke) and the idle air adjusting screw. Am I missing something here? Any help would be greatly appreciated. How many turns out should the idle air screw be? Does the fast idle screw for the choke ever come completely off the fast idle cam? Maybe this is what I'm missing. However, I have that screw adjusted so it would idle as high as possible. Now I'm confused. ARe you? Also, how is oiling achieved for the valve train? It doesn't appear to oil through the push rods and I saw no oil being pumped up while running it with the valve cover off. I have to assume that oil passages are plugged up. Where are they located? There's a lot of old burned on oil "gunk" on there. dave |
| Author: | Doctor Dodge [ Sun Nov 28, 2004 10:16 pm ] |
There should be two screws "side by side" on the carb. linkage. One screw adjusts the choke's fast idle, the other adjusts the "curb idle", after the choke comes off. (Yes, once the engine is warm and the choke comes-off, the fast idle screw will not longer touch the "staircase" cam) It sounds like you may be missing the "curb idle" screw. (see photo below) As for no oil from the rocker arms, it does take a minute or two of running for the oil to get up there. There is also a small "indexing" flat on the rocker shaft that goes forward and points up, if the shaft is not in the proper "indexed" position, oil will not come out of the rocker arms. As a test you can spray carb cleaner into the tip hole of the rocker arm, if the oil passage is clear, the cleaner will come out the top oil port in the rocker arm. http://www.slantsix.org/articles/hrm-sl ... ov-pg3.jpg DD
| Author: | Eric W [ Sun Nov 28, 2004 10:27 pm ] |
Sounds like you have a 1945 Holley 1bbl. The curb idle screw is located on the passenger side of the rear of the carb, behind the fast idle cam. Yes, with the choke adjusted properly, the fast idle screw should not make any contact with the cam. To adjust the mixture screw, get a vacuum guage and turn the screw in untill the engine starts to die. Turn the screw out to get the highest vacuum reading. Oil is fed to the rockers through the rear hole that the rocker arm shaft bolt goes into. Oil flows through the shaft, out holes and up and out of the rockers. Has any work been done to the head? Take off the rockers and shaft? There is only one right way the shaft should go on: that is with a small flat on the rocker arm shaft should be on top, toward the front of the engine. The long bolt should be installed on the rear of the shaft. The slant dosn't send oil up the push rods. Confused? |
| Author: | 74360scamp [ Mon Nov 29, 2004 5:25 am ] |
Gentlemen, thanks for the info. This gives me something to work with. The car ran fine when I pulled it into the garage and until the hold down bolts came loose and let 3 push rods move out of contact with their respective rocker arms. The guy I bought it from replaced some push rods cause someone had tried to start the car without taking the proper precautions and bent some push rods. Don't know if he took the shaft completely off or not, shouldn't have needed to - I didn't take it off to move the push rods back into position. I'll check for the indexing flat on the shaft to make sure its in the correct position and try the carb spray check for the oil passage. I probably just have the carb adjustments messed up a bit, but I'll look to see if it looks like I'm missing the curb idle adjusting screw. Again, thank you very much for your help. dave |
| Author: | Doctor Dodge [ Mon Nov 29, 2004 8:02 am ] |
Have you done a valve adjustment? Is the lash set to .010 on the intake valves and .020 on the exhaust? If the valves are not adjusted correctly, the engine will run rough at idle. DD |
| Author: | 74360scamp [ Mon Nov 29, 2004 8:29 am ] |
| Post subject: | Valve Adjustment |
DD, thanks for responding. I have only done a preliminary valve adjustment so I could get it started. I adjusted them 13 and 22. I was going to let it run and warm up to do the 10 and 20, but then noticed no oil showing up on top of the head. That's why the question earlier about the oiling of the valve train. I did look this morning and the shaft is mounted correctly with the flat up and to the front of the block. I am going to get some spray carb cleaner to clean things off a little cause I can't find any little holes in the rocker arms or anything else where the oil should be coming from. dave |
| Author: | Doctor Dodge [ Mon Nov 29, 2004 8:45 am ] |
If you need a good used rocker arm assembly that oils, let me know, I have a few extras. I can also supply a reconditioned racker arm assembly. DD |
| Author: | 74360scamp [ Mon Nov 29, 2004 8:48 am ] |
| Post subject: | Rocker Arm Assembly |
DD, thanks very much. I'll let you know. I really don't want to put much into this little motor cause it will be coming out eventually. But I want to sell it (actually, the whole drive train) as a running motor, still in the car type of deal. But, if I have to get some better parts, I will. I have a can of Sea Foam that I'm thinking of pouring a portion of into the crankcase. Again, thanks very much, and I'll let you know. dave |
