It is currently Mon Nov 30, 2026 7:02 am
PostPosted: Mon Nov 29, 2004 7:26 pm
Does anyone know where to get the ARP head studs, and approx the price of a set?
Also if I cannot afford them I might want to use the hardended Steel Washers - here could I get them? I am Guessing regular hardware store washers will not cut it.
Thanks for your help.
PostPosted: Tue Nov 30, 2004 8:13 am
Call ARP,
Here is the p/n info:
http://www.slantsix.org/articles/ARP-st ... rdware.htm
PostPosted: Tue Nov 30, 2004 12:42 pm
not that it has anything to do with the topic, greg, but that's some serious ride. :)
congratulations!
Juan Ignacio Caino
PostPosted: Tue Nov 30, 2004 6:05 pm
Thanks, but it was more show than go That is why I now have so many engine questions. Hope to get some more go this year.
PostPosted: Wed Dec 01, 2004 2:25 pm
For hardened washers just go to any hot rod shop and get a set of head bolt washers for a small block Chevy. You will get enough for 2 sets of head bolts. The set i got was around $7. :shock:
PostPosted: Wed Dec 01, 2004 6:50 pm
Well Summit had the arp studs in stock for the head - $76.00 for the set - I figured that was reasonable - so I decided to go that route, Next I probably get the conn. rod studs.
I had decided aganist the main studs, because I am getting one of Mike Jefferys' Windage tray kits, so I just stick with stock stufff there.
Thanks again for all the help.
PostPosted: Wed Dec 01, 2004 7:46 pm
You've gotta torque these studs a little higher than the stock bolts. Follow the instruction sheet or reference ARPs web site for info.
Mitch
