It is currently Mon Nov 30, 2026 7:02 am
 Post subject: Theoretically....
PostPosted: Tue Nov 30, 2004 4:52 pm
Site Admin
I scored a nice fresh head for my engine build. This will allow me to cut the prerequisite hundred off it, and run the engine in on my old head, saving the freshly built one for after break-in.
Still seriously considering the long rod build.
But.
There's always a but.
In a long rod build, I'm thinking to de-stroke to square to raise the engine speed. 3.50 X 3.50.
I can play with the math all I want, but I'm no engineer. (Unless you count control systems which don't seem to use the same application mathematics.)
I can play with what I think I know, or ask the guru's!
What do you think?
CJ
PostPosted: Tue Nov 30, 2004 5:58 pm
You can do the long rod build up here as many have. Its a proven package and a path that is already beaten. your stroke is still long, but the guys on here will all tell u that combination will live to 6000 rpm safely. which is plenty of rpm for the street. Also they will tell u that the extra cubes will big a help down low. But if u really want a 7000 rpm screamer. Keep the car under 3000 lbs and find a 198 engine complete (stock 3.40" bore x 3.625" stroke) Doug Dutra did this with a .100" overbore and put it in a lighter 170" "low deck" block. the result is 210 cubes and short stroke. Check out the Articles on here about stroking. The biggest enpense will be finding good pistons. I often think about how neat that combo would be in areally light early 60's A body and a 5 speed. Bmw M3 wannabe 8) add some disc brakes, big wheels and tires and other handling mods. Anyhow thats just my mental salavtions.. good luck, and happy building.
The worst mistake a boss can make, is not say "well done"
PostPosted: Wed Dec 01, 2004 9:57 am
Why would you spend all that money to make it slower? Not to mention the piston weight - have to be longer by 1/2 the reduced stroke distance.
