running like crap
https://slantsix.org/forum/viewtopic.php?t=11053
Page 1 of 1
Author:  newpoppop [ Mon Nov 29, 2004 3:47 pm ]
Post subject:  running like crap
ok, It looks like a lot of folks are having tuning problems, so I will throw mine in too...
66 Valiant, 225 2 bbl. was running fine, going down road fine, bam, starts bucking, and backfiring. idles fine, when it revs, the tach goes nuts, flopping around. (Needle) again, idles fine. I was able to drive it a little to get it home, but it was tough. swapped in a new coil, and coil wire. same problem. seemed to be running hot, swapped in a 160 degree thermostat. same problem.
help me here guys. pulling my hair out, and this is a daily driver... I guess I could use a couple more days off....
thanks
Chris
Author:  Guest [ Mon Nov 29, 2004 4:04 pm ]
You might check your timing and see if it correct. Also the usual spark gap if you have points and check the plugs to see what color and condition they are in. Hard to tell without being there.
Author:  Dennis Weaver [ Mon Nov 29, 2004 4:21 pm ]
Got points? That's the first place I'd look. Check the condition and gap and also see that the points plate is held down securely... If that little triangular spring on the bottom side breaks or comes loose, all hell breaks loose with the firing. This can effect electronic ignition, too. Check the condition of the cap while you are looking at the points. If you've got Chrysler electronic ignition retrofitted, I'd suspect the Control Unit.
D/W
Author:  argentina-slantsixer [ Mon Nov 29, 2004 6:48 pm ]
wouldn't hurt to check your cap and rotor too, and the wires.
Author:  newpoppop [ Tue Nov 30, 2004 4:34 am ]
Post subject:  running like crap...
I failed to mention it has a prestolite ignition conversion. old time electronic ignition... (70's style, NOS setup...)
I checked everything, I am trying to see if the timing chain has stretched to the point that it is unfaithful...
thanks for all of the suggestions.
Chris
Author:  Dennis Weaver [ Tue Nov 30, 2004 7:08 am ]
That's a big thing to leave out! :shock:
I have no experience with these. However, the fact that your tach is going crazy leads me to believe that your problem has to do with spark scatter and the ignition going crazy. I doubt the timing chain has anything to do with it if it idles ok, as you have said. Do you still have the original points distributor? Try swapping it in temporarily to troubleshoot and see if the problem can be located to the Prestolite setup.
D/W
Author:  newpoppop [ Tue Nov 30, 2004 8:18 pm ]
Post subject:  running, finally...
We found the problem to be the prestolite trigger in the distributor. what a pain... but now I have an engine with only 20K Miles on it, and it is much more snappy than the old one...
Thanks to all that offered suggestions. 11 hours to swap a slant for a slant. don't ask... should have been a 4 hour project... I am so sore.
Goodnight...
CHris
Author:  Dennis Weaver [ Tue Nov 30, 2004 11:20 pm ]
You changed the MOTOR because of an IGNITION problem?!! :shock:
D/W
Author:  Eric W [ Wed Dec 01, 2004 12:42 am ]
D/W
Well, thats one way to fix it... :lol: :lol:
Author:  argentina-slantsixer [ Wed Dec 01, 2004 6:32 am ]
beefy way to solve an ignition problem, huh? :lol: :lol: :lol: :lol:
Author:  newpoppop [ Wed Dec 01, 2004 12:57 pm ]
Post subject:  running funny
Not exactly. I had planned on doing it on Saturday, because I want to rebuild this engine... I just moved the schedule up. but I guess in reality, it looks that way..
