It is currently Mon Nov 30, 2026 9:43 am
 Post subject: Slant 6 blocks
PostPosted: Sat Nov 27, 2004 5:48 pm
Hello, New guy here :lol:
I was wondering if there are any real advantages with blocks that are laying around in yards and so on? mech or hydro cammed and on. I'm planing on building a slant for my truck , 1983 Dodge Ram 4wd 4 spd 397K slant in there now :shock: its starting to makes noises so i better start thinking about building an engine soon
Patrick
PostPosted: Sun Nov 28, 2004 9:39 am
You may want to go over to the article section of the site and do some reading.
http://www.slantsix.org/articles/dutra- ... blocks.htm
All the SL6 engines a basically the same but you will want to use a 1968 or later "big piolt hole" crankshaft engine.
Just find one that is not all rusted or blow-up and you should do OK.
PostPosted: Sun Nov 28, 2004 9:06 pm
I have a 80 block here i'm going to work with. now the task is finding a forged crank for pennys :D I'm hoping on hitting the 200 hp mark with good street manners like 89 octain and maybe some boost later on :twisted:
Patrick
PostPosted: Sun Nov 28, 2004 9:40 pm
Look for a 68-75 "short block" to work with if you want to go with a forged crank. The later cast crank blocks will not accept the forged crank without a lot of special work.
PostPosted: Mon Nov 29, 2004 6:21 pm
I know of 2 in a local junkyard ones a 73 with no head others a compleat one from a 70 or 71 duster. How much would be a fail deal for the whole motor (non running)?
Patrick :D
