Ballest resistor ? Old MSD chrysler box
https://slantsix.org/forum/viewtopic.php?t=11056
Author:  golembieski [ Mon Nov 29, 2004 6:26 pm ]
Post subject:  Ballest resistor ? Old MSD chrysler box
Ok this is a good one. I am going to be running a old msd chrysler box on my slant and a blaster 2 coil. Is there a rule of thumb on what resistance to use. I am going to hook up all 5 wires to run the old msd box and it looks like i am going to need a 5 Ohms for running the #3 wire (just because they were made to plug right in to a lean burn setup) but what should i run to the coil. The msd blaster Info says Primary Resistance 0.700 ohms Secondary Resistance 4.70K ohms but i'm still going to need the dual resistor for the current going to 3.
What i'm thinking is get the dual ballest resistor and just use it for the 5Ohms side and use the resistor with the msd blaster to power the coil.
Can i run .5 Ohms to the coil insted of the .7Ohms and be safe?
Frank
Author:  Seis Inclinado [ Mon Nov 29, 2004 9:35 pm ]
Electronic Ignition Wiring Diagrams
Dual resistor wiring diagram. Note that the "Compensating" resistor is 0.5 ohms, NOT 5 ohms as shown here.
Chuck
Author:  golembieski [ Mon Nov 29, 2004 9:53 pm ]
Ya i think thats how i'm going to do it with the duel ballest resistor.
Frank
