| So how do you like the Demon engine now? https://slantsix.org/forum/viewtopic.php?t=11058 |
Page 1 of 3 |
| Author: | midpenmopar [ Mon Nov 29, 2004 7:18 pm ] |
| Post subject: | So how do you like the Demon engine now? |
Cool sticker, huh! Stu
| Author: | golembieski [ Mon Nov 29, 2004 7:32 pm ] |
demon 1bbl ? But Real nice under the hood.... Did you start it yet? |
| Author: | midpenmopar [ Mon Nov 29, 2004 8:03 pm ] |
Quote: demon 1bbl ?
But Real nice under the hood.... Did you start it yet? Yes, it runs sort of ok??? I am dealing with what might be a BAD brand new rebuilt Holley 1920 carb. Sure wish i could find a NOS one though. Stu |
| Author: | 63Dart [ Tue Nov 30, 2004 5:19 pm ] |
Wow - looks cool - you might be able to find a rebuilt on ebay - I'm going to try and rebuild mine (Carter BBS)... |
| Author: | Scat [ Tue Nov 30, 2004 6:19 pm ] |
Looks good. I have a Factory 68 (i think) remained carter carb on my slant. Pretty soon to have a Mega Squirt MPFI Patrick |
| Author: | 63Dart [ Wed Dec 01, 2004 10:48 am ] |
Here's my setup (with the two carbs I have to rebuild): |
| Author: | dart63 [ Wed Dec 01, 2004 11:14 am ] |
Someone likes playing with a steel tubing bender...... Nice set-up. Kevin |
| Author: | 63Dart [ Wed Dec 01, 2004 11:20 am ] |
Thanks, it's J.C. Whitney's best! I didn't think it would actually bend the tubing 180 degrees like it says - but it does... k |
| Author: | midpenmopar [ Wed Dec 01, 2004 5:23 pm ] |
Quote: Here's my setup (with the two carbs I have to rebuild):
WOW! That looks great! Did adding the headers and the dual carbs help really make a big change in the power of the engine? Stu |
| Author: | 63Dart [ Wed Dec 01, 2004 5:50 pm ] |
Thanks Stu! Well I've got a bad cam lobe (the engine has lots of miles, and the oil wasn't changed too much before me), so it's always missed (actually backfires) on full throttle. However, at part throttle, I can feel a lot more torque. It sounds cool, too. The two flowmasters give it a raspy metallic sound when I rev the motor, and when I get up past 65. My next big project is to put in a rebuilt motor. I also have a Mopar Performance cam with 460 lift, which I'm thinking about sticking in the rebuilt. But more lift is supposed to equate to less torque, so I may not. I like the whole torque thing. k |
| Author: | DustU [ Sat Dec 04, 2004 8:03 pm ] |
i believe that more lift equals more torque or more low rpm power thats an EXTREMELY clean engine compartment lots of hard work, wow- I'm really impressed, very nice job |
| Author: | SlantSixDan [ Sun Dec 05, 2004 12:47 pm ] |
| Post subject: | Re: So how do you like the Demon engine now? |
Looks like a nice, clean engine, but I definitely don't like your fuel filter sitting right smack dab above a very hot exhaust manifold runner. You might not be unlucky enough to have a leak that drips on the hot manifold and burns your car down (how lucky do you feel?) but this positioning is begging for starting and driveability problems. Remove the metal line that runs from the fuel pump to the carburetor and throw it away. Install a 5/16" IV-flare-to-5/16"-hose-barb brass fitting in the fuel pump outlet and another in the carb inlet. These fittings can be had from any well-stocked hardware store that carries the Dorman "orange drawers" line of springs, fittings, etc. The Dorman part number is 492-024; Everbrass number is 1791. Between these fittings I run a length of 5/16" I.D. *fuel injection* hose (marked SAE 30R9, not the less heat-resistant old-fashioned 30R7 stuff that doesn't do well with modern gas formulations over time -- be sure to get fuel injection hose clamps, too). This line runs vertically up from the fuel pump, over the valve cover, and across to the carburetor. The fuel filter (with a metal can, the plastic ones sometimes don't do well with oxygenated gas) gets installed vertically so it's right behind the alternator...this keeps it away from heat and the alternator fan cools it down further. Much better than the stock location where it gets heated up by the exhaust manifold! With this setup, a lot of the bitchy hot and cold start problems disappear, because you're no longer boiling fuel in that metal line when you shut off the engine. Try it, you'll like it! |
| Author: | 63Dart [ Sun Dec 05, 2004 4:01 pm ] |
Yes, sounds like a good setup - I have the MOPAR book on Six Cylinder racing, and they also recommend metal fuel filters. (Don't break in crashes like the plactic and glass ones do). I also like the idea of using the fuel injection line and the fuel injection clamps - I've never liked the way that MP routed the original metal lines anyway. Thanks for the part numbers - I'll see if my local OSH or True Value has them. I'm not running a choke right now - so anything that helps with starting is good (it does have problems starting after its been run for a while and then shut off for about an hour). I also like being safe. I'd feel really crappy if I led to the demise of this 41 year old survivor car! k |
| Author: | textoad [ Sun Dec 05, 2004 4:36 pm ] |
A couple of things to think about along the lines (no pun) of ditching the metal line. Wouldn't the rubber line retain the heat more because it is insulating and because the heat will be trapped in the line? Also wouldn't the reflective metal line, rubber is black and absorbtive, wick away the heat more? Also the metal line is thin and the gas in the line is closer to the surface causing more cooling effect. I guess it works both ways though because the gas is closer to the heat source as well. Anyways something to ponder. Also the FI ine is 34 cents per inch at my local Checker Auto Parts. That's 25 dollars for 6 feet of it. Probably not necessary at less than 10 PSI. Just my 2 cents. |
| Author: | SlantSixDan [ Sun Dec 05, 2004 5:26 pm ] |
Quote: Wouldn't the rubber line retain the heat more because it is insulating and because the heat will be trapped in the line?
No, with the rubber line, the heat never gets into the fuel in the first place. The metal line near (and clamped to) the engine is what transfers the heat to the fuel. The insulating effect of the rubber line is precisely what keeps the fuel cooler.Quote: Also wouldn't the reflective metal line, rubber is black and absorbtive, wick away the heat more?
No. We're talking about conducted heat, not radiated heat.Quote: Also the metal line is thin and the gas in the line is closer to the surface causing more cooling effect.
The gas line is not a cooling radiator, it is a heating stove.Quote: I guess it works both ways though because the gas is closer to the heat source as well.
It doesn't work any "both ways". Just one.Quote: Also the FI ine is 34 cents per inch at my local Checker Auto Parts.
Check carefully; that's probably the price for SAE J30R7 carburetor-type line.Quote: Probably not necessary at less than 10 PSI. Just my 2 cents.
Well, I guess I'm putting in 4 cents, 'cause I've actually done this and not just pondered it. To my mind, it's worth spending the extra money for the extra safety margin that the fuel injection hose provides.
| Page 1 of 3 | All times are UTC-08:00 |
