| ARP STUDS or Hardened Washers? https://slantsix.org/forum/viewtopic.php?t=11059 |
| Author: | Greg Ondayko [ Mon Nov 29, 2004 7:26 pm ] |
| Post subject: | ARP STUDS or Hardened Washers? |
Does anyone know where to get the ARP head studs, and approx the price of a set? Also if I cannot afford them I might want to use the hardended Steel Washers - here could I get them? I am Guessing regular hardware store washers will not cut it. Thanks for your help. |
| Author: | Doctor Dodge [ Tue Nov 30, 2004 8:13 am ] |
Call ARP, Here is the p/n info: http://www.slantsix.org/articles/ARP-st ... rdware.htm DD |
| Author: | argentina-slantsixer [ Tue Nov 30, 2004 12:42 pm ] |
not that it has anything to do with the topic, greg, but that's some serious ride. congratulations! |
| Author: | Greg Ondayko [ Tue Nov 30, 2004 6:05 pm ] |
Thanks, but it was more show than go That is why I now have so many engine questions. Hope to get some more go this year. |
| Author: | slantzilla [ Wed Dec 01, 2004 2:25 pm ] |
For hardened washers just go to any hot rod shop and get a set of head bolt washers for a small block Chevy. You will get enough for 2 sets of head bolts. The set i got was around $7. |
| Author: | Greg Ondayko [ Wed Dec 01, 2004 6:50 pm ] |
Well Summit had the arp studs in stock for the head - $76.00 for the set - I figured that was reasonable - so I decided to go that route, Next I probably get the conn. rod studs. I had decided aganist the main studs, because I am getting one of Mike Jefferys' Windage tray kits, so I just stick with stock stufff there. Thanks again for all the help. |
| Author: | MitchB [ Wed Dec 01, 2004 7:46 pm ] |
You've gotta torque these studs a little higher than the stock bolts. Follow the instruction sheet or reference ARPs web site for info. Mitch |
