It is currently Sun Nov 29, 2026 12:33 pm
PostPosted: Sun Dec 05, 2004 5:52 pm
OK, so, I got all the push rods in place, cold set the valves and started it up so I could "hot" set the lash. After a couple minutes, I realized that the oil pressure idiot light was still on - no pressure! I shut her down and started looking for the pressure sending unit. Found it and pulled off the connector, cleaned the connector and tip of the sensor and tried it again. Still no pressure - according to the red idiot light.
Back up a little and I can tell you what I've done. I had a miss in the engine and eventually discovered that three push rods were just "sitting" there. Nothing broke or bent (the guy I bought the car from had replaced some push rods that were bent by someone trying to start the engine without taking the proper precautions), a couple of the hold down bolts had backed out. Well, I think when the guy replaced the push rods, he never retorqued the hold down bolts, cause they were all loose. Since I have it opened up, I decide to try and clean off some of the burned on oil deposits, etc. Over the course of a few nights, I sprayed the valve train with engine degreaser many times. I used 5 or 6 cans. Then, I cleaned it all off with carb cleaner spray.
Everything looked pretty good so I set the valve lash at 13 and 22 (cold) and started her up so it could get hot and then I could do the hot lash.
Is it possible that enough of the engine degreaser got into the oil pan and the oil is sitting on top of the oil and the degreaser is not viscous enough for the pump to pump it? I know I'm grasping at straws here, but I didn't really want to replace the oil pump since I'm going to be selling this engine (in fact, the entire drive line). Any ideas or suggestions?
Thanks very much. Oh, she runs much smoother now - the miss is gone. Still need to adjust those valves and do a little carb tuning and set the timing.
dave
PostPosted: Sun Dec 05, 2004 6:16 pm
You might have a defective sending unit. Install a mechanical gauge and you'll know exactly what the oil pressure is.
 Post subject: No Oil Pressure
PostPosted: Sun Dec 05, 2004 6:40 pm
I have a buddy who has a mechanical guage we could hook up, if we know what size threads we need. Any idea.
dave
PostPosted: Sun Dec 05, 2004 11:44 pm
You have five or six cans of degreaser and a can of carb cleaner in your sump?
Please...drain the oil before you do anything else.....
Regards, Andrew.
PostPosted: Mon Dec 06, 2004 1:59 am
I agree, fill it with fresh oil.
I *think* the idiot light sender threads are 5/8 pipe but don't quote me on that.
Until you get a gauge, take the valve cover off or at least the oil filler cap while running and see if the rocker arms are getting oiled. That would tell you if your getting pressure up to the top of the engine. Thats assuming all the passages aren't gunked up.
PostPosted: Mon Dec 06, 2004 6:47 am
3/8" NPT (pipe) threads...
If it ain't broke, fix it!
PostPosted: Mon Dec 06, 2004 7:26 am
I agree with typhoon, let every drop of the "Emulsion" that is in the pan drain, then refill with fresh oil before making your next move.
Probably would have been a good idea to remove the Rocker to clean it. Good luck.
:? At this point I would consider dropping the pan, that engine cleaner turns into a white greasy emulsion.....it may stick to the pan and create problems for awhile.
 Post subject: No Oil pressure
PostPosted: Mon Dec 06, 2004 7:30 am
Yep, I think all of you are probably correct. Either way, I think I need to drop the pan (oh, boy) and get all the degreaser out. I may just go a head and replace the oil pump and either clean or replace the screen while I'm at it. Live and learn..... eventually. Thanks, folks. I think I may go a head and pull the entire rocker arm assembly and get it hot tanked and try and make sure everything is clear, too.
Thanks,
dave
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 7 guests
