Chrome valve cover with no oil spout WTF?
https://slantsix.org/forum/viewtopic.php?t=11067
Author:  textoad [ Tue Nov 30, 2004 7:39 pm ]
Post subject:  Chrome valve cover with no oil spout WTF?
Allright.... so I'm doing the total "reeebuild boogie" here and I order (6 months ago)a chrome valve cover so my son can be proud of his /6... and this puppy has no oil hole. WTF Hover? It fits the slanted beast head just tits... but no oil hole!??? Can someone splain this to me pleeease?
Oh Luuuucy.........!!!!!!!! ???
Where does the juice (oil) go when operational? Maybe through the PCV valve? No comprendo?
I shouldn't have to ask this question. I'm a reasonable guy.
Author:  golembieski [ Tue Nov 30, 2004 8:23 pm ]
Through the hole for the push in breather!
then you put your PCV in the other hole
Author:  dart63 [ Wed Dec 01, 2004 7:32 am ]
The chrome valve covers I see advertised regulary are a risk at best.
They have a push in breather hole, and a PCV hole, but no third hole just for oil. A lot of them also do not have oil splash guards under the openings, so the chance of oil making its way into the breather line or fouling the PCV increases not to mention the oil doesn't circulate(drip) back onto the rocker components as designed so oiling properly is an issue.
I always ask the seller for a look at the bottom side before purchasing, and count the holes.......
Author:  textoad [ Thu Dec 02, 2004 7:49 am ]
Yea it looks like I screwed up on this one. It fits nice and looks great but it's doesn't have the splash gaurds. I'll take a closer look this weekend and see if I could do some mods to it. Seems like splash gaurds could be added after the fact. The lack of a spout for the oil, I guess I could use the existing holes for adding oil. But getting the right dripping effect for lubrication really bothers me. I might call a local chrome shop and see what they would charge to do my stock cover.
Thanks
Author:  Eric W [ Thu Dec 02, 2004 9:43 am ]
You could also paint the stock valve cover with black wrinkle paint. Thats what I did with mine. If its good enough for Hemi's and the Hi-Po 273, its good enough for me! 8)
Author:  textoad [ Thu Dec 02, 2004 9:47 am ]
That's true but chrome is so cool. By the way and local shop quoted me 50dollars over the phome for chrome plating.
Author:  72swing [ Fri Dec 03, 2004 12:19 pm ]
Post subject:  Shop quoted you $50 to plate a Valve cover???
What shop? Where?
Locally I got a quote of between 150-300 dollars to chrome a Valve cover (and 2 pulleys). I don't know if they are just high priced here or what, but 50 bucks is VERY reasonable to me. I am also considering doing a cool powder coat instead.
Author:  Pierre [ Fri Dec 03, 2004 2:58 pm ]
$50 sounds more like a chrome-colored powder coat, not actual chrome. I hear those shiny powder coats are supposed to be pretty good though.
Author:  72swing [ Fri Dec 03, 2004 7:46 pm ]
I was commenting that textoad's "Local shop price" of fifty bucks would be astounding considering what they want roun hya! :)
I have seen the new metalic powder coats too, they do one at a local shop here that looks like it's liquid smoke-chrome... its incredible... and only 75 bucks... compared to the 300 that it'd cost me for good show quality chrome :)
Author:  mightyss [ Sat Dec 04, 2004 1:16 pm ]
Post subject:  chrome
i just got a couple of quotes on chroming a 7 1/4 rear end cover 40- 50$. so 50$ for a valve cover would be a deal......................steve
Author:  Bob D [ Sat Dec 04, 2004 8:35 pm ]
This looks like the Mopar Performance cover that I have. If so it has the baffles and is worth a lot more than the current bid. You could contact the seller and ask. http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33627
Bob D
Author:  zorg [ Mon Dec 06, 2004 11:15 am ]
That v/c lookes nice, but there are no baffles in it. You can see the concrete floor through all the holes.
Author:  textoad [ Mon Dec 06, 2004 11:44 am ]
The place that quoted me 50 is called Ideal Plating in South Tucson. Another place quoted me 65 but both places said they would have to see it first. It's possible they were low balling it to get me in the door. Yes it was chrome not paint.
Author:  Bob D [ Mon Dec 06, 2004 1:09 pm ]
You're right Zorg. I didn't even notice that. Strange though because other than that it looks like the MP piece.
Bob D
Author:  Super6 [ Mon Dec 06, 2004 1:54 pm ]
Looks exactly like the one I have on my slant---but mine has the baffles (MP unit):
<img src="http://img.photobucket.com/albums/v514/Slanted_Mind/EngineBayPassenger.jpg" width=400>
-S/6
