It is currently Sun Nov 29, 2026 7:02 pm
 Post subject: forged pistons
PostPosted: Fri Dec 03, 2004 7:31 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... eName=WDVW
These might be possible for 225 with long rods.
3.4375 standard bore.
Not sure about the comp. ht. but I think it's around 1.57"
.8009 pin. would need to bush rods.
Franklin
'61 Valiant
PostPosted: Fri Dec 03, 2004 7:38 pm
CD is 1.585". Very strong but very heavy. You can save weight by taking a big whack off the dome, also valve relief = no problem.
However: they're made for pressed rods. If you don't want to do this (press them on your rods) you can't use them. Trust me: I wrote/phoned 20 shops who all advertise "we can do anything" and asked them to shorten the pins and cut lock grooves, and the answers ranged from "impossible", to "we don't do that", to "$100. per piston".
I would use the KB replica, same sizes but has pin locks, weighs less, tighter skirt clearance.
Users browsing this forum: Bing [Bot] and 6 guests
