It is currently Sun Nov 29, 2026 8:39 am
 Post subject: holley 390 questions
PostPosted: Mon Dec 06, 2004 7:47 pm
I have a mildly built slant 0.030" over, milled head, bowl work oversized valves, mp 460 cam, mp header and an offenhauser intake with a 600 holley. The combo runs great but the carb is a little too big. I've been looking to go to a 390 holley for a little while. Through a friend I found a double pumper 390 rebuilt ready to go for quite a good price. Is a double pumper a bad choice for driving a car mostly on the street or should I just keep looking and find a vacuum secondary 390? Does anyone run a 390 double pumper and what jetting, pumpcams etc. are you using?
PostPosted: Mon Dec 06, 2004 11:19 pm
The problem with a mechanical secondary carb (double pump Holley) on a small displacement engine (Slant Six) is that the engine can not take all the CFMs at lower RPMs. Basically you will get a big bog if you stomp the carb wide open from idle or at low RPMs.
PostPosted: Tue Dec 07, 2004 6:43 am
I think, for the street, vacuum or air-valve secondaries are the way to go. Mechanical secondaries are much better suited for the drag strip. Although new vacuum secondary 390s are quite expensive, you can probably find a used one much cheaper on eBay.
Frank
PostPosted: Tue Dec 07, 2004 8:24 am
CARTER! :D :lol:
D/W
If it ain't broke, fix it!
Users browsing this forum: Badvert65, Google [Bot] and 4 guests
