| Valve spring questions?? https://slantsix.org/forum/viewtopic.php?t=11087 |
| Author: | HyperValiant [ Thu Dec 02, 2004 8:21 pm ] |
| Post subject: | Valve spring questions?? |
I know that alot of members here run the Comp Cams 264s and was wondering if anyone has had valve spring issues(coil bind). I have this cam installed in a 170 with .130 off the head(low compression pistons were installed by mistake and the head was shaved more to make up for the difference-still only has about 9.3 to 1 c.r.).I did not use shorter push rods as it seems that the adjusters in rocker arms allows enough adjustment to compensate. The engine runs well and will rev nicely(havnt reved over three grand yet but revs freely to that rpm) but the valve spring (stock slant) only has about .020 clearance between the coils at full lift,Im worried about what will happen when I take it out and run it up to 5000-5500 rpm? BTW,the valves are correctly adjusted to Comps specs and the cam was degreed to be straight up. What is others experience with this situation??All help is greatly appreciated. HyperValiant |
| Author: | HyperValiant [ Fri Dec 03, 2004 7:30 pm ] |
| Post subject: | Update. |
I remeasured the springs this afternoon and found that they are .020 only on the end coils and .036 in the middle coils of the spring. HyperValiant |
| Author: | HyperValiant [ Sat Dec 04, 2004 9:22 pm ] |
No takers on this one??? HyperValiant |
| Author: | Doctor Dodge [ Sun Dec 05, 2004 9:29 am ] |
Most cam manufacturers say to check the spring coils using a .010 thick feeler gauge which should pass freely between all five coils. This gives a total "stack" clearance of .050 min. It sounds like you have plenty of clearance. Let us know where it "redlines" once you break it in and spin it up. DD |
| Author: | HyperValiant [ Sun Dec 05, 2004 6:21 pm ] |
Thanks Doc,I Was concerned because I read a article at Lunatis site that mentioned needing .060 clearance but maybe that was combined and not between each coil. I apolagize for some these questions but I would rather ask now and not pay later.....if you know what I mean. Thanks again HyperValiant |
