| Timing tape https://slantsix.org/forum/viewtopic.php?t=11095 |
| Author: | golembieski [ Fri Dec 03, 2004 3:49 pm ] |
| Post subject: | Timing tape |
I was wondering if any body had used a timing tape for a big block on a slant. A bigblock is 7.250 damper and i think i measured the slant at 7.5. Just wondering |
| Author: | Charrlie_S [ Sat Dec 04, 2004 4:51 am ] |
I don't know how you would do it. The slant damper has the pulley made right into it. There is not enought flat area to put the tape on. I took a triangular file and added some notches, every 5*, for about 40*. Then added other marks every 120* for putting each piston at TDC. |
| Author: | argentina-slantsixer [ Sat Dec 04, 2004 10:24 am ] |
I was wandering thru some automotive pages and I ended up on a site that sells bunch of nice tools. I don't remember the site but they had some timing "snake" they called that, some sort of plastic add-on for 3 side bolts harmonic balancer. Was intended for big block, but the holes match on a slant damper. Good luck. |
| Author: | golembieski [ Sat Dec 04, 2004 6:02 pm ] |
I just figured that i would cut the tape down so i could fit it on the small gap i had ... I think i would only have to cut half the dia off the tape |
