It is currently Sun Nov 29, 2026 6:36 pm
 Post subject: Timing tape
PostPosted: Fri Dec 03, 2004 3:49 pm
I was wondering if any body had used a timing tape for a big block on a slant. A bigblock is 7.250 damper and i think i measured the slant at 7.5.
Just wondering
PostPosted: Sat Dec 04, 2004 4:51 am
I don't know how you would do it. The slant damper has the pulley made right into it. There is not enought flat area to put the tape on. I took a triangular file and added some notches, every 5*, for about 40*. Then added other marks every 120* for putting each piston at TDC.
PostPosted: Sat Dec 04, 2004 10:24 am
I was wandering thru some automotive pages and I ended up on a site that sells bunch of nice tools. I don't remember the site but they had some timing "snake" they called that, some sort of plastic add-on for 3 side bolts harmonic balancer. Was intended for big block, but the holes match on a slant damper.
Good luck.
Juan Ignacio Caino
PostPosted: Sat Dec 04, 2004 6:02 pm
I just figured that i would cut the tape down so i could fit it on the small gap i had ... I think i would only have to cut half the dia off the tape
