| thermo gauge jumps to 250+! even on cold starts https://slantsix.org/forum/viewtopic.php?t=11099 |
| Author: | guest [ Fri Dec 03, 2004 10:00 pm ] |
| Post subject: | thermo gauge jumps to 250+! even on cold starts |
When i get into the car and turn the key the gauge will jump formward and max out. I dont know if this is a shortage problem, or if my thermostat is just goin out. oy veigh help me out! |
| Author: | Pierre [ Fri Dec 03, 2004 10:21 pm ] |
If it happens the instant you turn the key on then it sounds like either your temp sensor malfunctioned or the wire going to it shorted to ground. Follow the wire back from the sensor and see if you can catch anything obvious, maybe a place where the insulation wore and allowed the wire to touch the body. |
| Author: | dart63 [ Sat Dec 04, 2004 6:40 am ] |
Or check for my favorite trick....especially after valve adjustment.....the dreaded....pinched under the valve cover trick.......where the temp sending unit wire runs arond the front corner of the head..... |
