It is currently Sun Nov 29, 2026 6:18 am
PostPosted: Sun Dec 05, 2004 4:21 pm
OK, gang last time I left off, the brand new factory rebuilt $130 Holley one barrel I just purchased was giving me fits. Then one of the guys from the MML sent me another carb he just rebuilt himself. I swap that one out today, and it works great, except he forgot to install the accelerator spring. :roll:
So it's off the car again and between the two carbs I make one that runs almost perfect. Still a slight hesitation, but nothing I cannot live with. BTW, I moved the accelerator arm to the furthest hole away and that seems to be the best.
I can now officially disassemble a Holley 1920 carb and put it back together in less than 10 minutes. :P Lets hope I can forget those skills soon.
Stu
P.S. thanks to Doug Dutra for helping me out again this afternoon. :D
President and founder of the Mid Peninsula Muscle Car Club
Hey check out my website: www.midpenmusclecar.com
We are always looking for more new friends.
PostPosted: Mon Dec 06, 2004 9:22 am
Good work Stu, you are now a "Holleytech"! (Is that like a lunatic?) :roll: :wink:
As with most SL6 stuff, it is pretty simple once you get in there.
Sounds like we should get together with my vacuum gauge and "Holley box" to see if we can "tweak-out" that last little bit of hesitation.
(Most likely a power valve (economizer valve) or vacuum advance pod adjustment.
Did you take note of the main jet size when you had the float bowl off?
PostPosted: Tue Dec 07, 2004 5:21 am
You know i did not check the main jet size. BTW, I would like to get the carb on a vacume guage though, that should be the last little bit i need to get it perfect.
PostPosted: Tue Dec 07, 2004 9:10 am
I am still having issues with my 1920. It came as a rebuilt from holley with a 55 sized jet in it. It wouldn't idle smoothly, and if you romped on it the car just died. you could baby it past this dead spot with multiple short pumps on the gas as you leave the light, but otherwise it dies. If I adjust the timing to get it to run good then it pings like crazy under hard accelleration.
I put a 64 jet in the carb and it immediately quit hesitating! It was running too rich though. I finally put a 58 jet in the carb and retimed it. Now it does hesitate, but it doesn't die. It also pings a little again!?! If you could tell us what the other fella did to the rebuilt carb I would LOVE to know... having to wait 1-3 seconds AFTER I hit the gas to go is making me crazy.
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
