It is currently Sun Nov 29, 2026 1:33 am
PostPosted: Wed Dec 08, 2004 2:51 pm
can you use stock plug wires or stock replacement wires with a msd ignition?
Using a msd ignition does eliminate the 5 prong box that is usually mounted (cant remember what its called) on the drivers side inner fender, correct?
PostPosted: Wed Dec 08, 2004 3:17 pm
Yes, using an msd box will eliminate the stock electronic ignition module.
You can use regular wires with an msd box/coil if they are up to it. I'd suggest buy the box (I'd suggest coil as well to eliminate the need for a balast resistor) and install them. Then check out your plug wires and see if they are arching (mix up a bit of dish soap and water in a spray bottle, then at night time with the car running spray the water around the wires to see if you can notice any sparks jumping). If they are, then replace them.
PostPosted: Wed Dec 08, 2004 3:48 pm
I tried the stock-type solid core wires with my MSD when I installed it, and everything electrical in the truck went nuts. The MSD instructions specifically say to not run solid-core plug wires. MSD, Jacobs, and I am sure a few other aftermarket suppliers make cut-to length 6 cylinder plug wire kits that are easy to make and will keep your electrical system sane.
-S/6
PostPosted: Wed Dec 08, 2004 4:04 pm
does anyone know of anyone that makes plug wires specifically for the slant that are not solid core? will a msd just be a bolt up and wire up deal with my electronic distributor?
PostPosted: Wed Dec 08, 2004 4:14 pm
MSD does not make a slant-6 specific kit. They do however make 6 and 8 cylinder genric, you cut to length, kits. It comes with terminals and a crimper. You just need a vice and cutter to assemble.
When I was shoping for the wires, I couldn't find a 6 cyl kit. Even online I believe the 6 and 8 cyl kits were only a few bucks different so I got the 8 cyl kit and had 2 spares. Lay your old wires out, and cut the new wires to match the length. Be forwarned though, MSD wires aren't cheap. My 'Spiral Core' set was near $100 iirc.
PostPosted: Wed Dec 08, 2004 4:22 pm
MSD install requires basic wiring skills, but is pretty straight-forward and easy. The instructions on MSD's Website, which are the same as the instructions that come with the MSD box wlak you through the install.
Abbreviated Instructions:
Original coil + wire to MSD small gage red wire.
Heavy gage Red and Black wires from MSD to battery + and -, respectively.
Small gage orange and black wires from MSD to coil + and -, respectively.
Green and violet wires from MSD to magnetic pickup in dist (I would need to check which wire from the pickup is + and which is -)
White wire from MSD is not used with an electronic dist, or can be used as an igniton "kill" switch.
I have not found any non solid-core wires made specifically for slants, which is not to say they do not exist, I have simply not seen/found any.
The cut to length kits are very easy to make, and you only need the most basic of tools (vice or hammer & hard surface, razor blade/exacto knife, and your two hands). I made all 7 (6 cylinders & coil wire) of my Jacobs wires in under 30 minutes. Cost IIRC was about $60 for the 6 cylinder kit (local performance shop).
<img src="http://img.photobucket.com/albums/v514/Slanted_Mind/EngineBayPassenger.jpg" width=400>
-S/6
PostPosted: Wed Dec 08, 2004 5:41 pm
guys that have msd ignitions, could you tell any difference over stock? in idle quality, power, anything?
PostPosted: Wed Dec 08, 2004 6:41 pm
My experience with MSD 6AL, MSD Blaster2 Coil, Jacobs 8.5mm wires:
Easier starting (fires right off)
Better idle--idle misfire is gone.
I picked up ~1 mpg, but the ignition I replaced was functioning very poorly (lean burn)
More 'butt dyno' power--but again, I replaced a poorly functioning ignition.
-S/6
PostPosted: Wed Dec 08, 2004 6:53 pm
When I ran stock Mopar Performance electronic ignition on my red car it would foul the 1 and 6 plugs at startup whenever it got below 45-50*. MSD cleared that right up. I drove it to work one day last winter when it was below 0* with the hood scoop uncovered. :shock:
MSD used to have a universal 6 cylinder kit that was around $40. :lol:
PostPosted: Wed Dec 08, 2004 7:11 pm
I see a bunch of questions about solid core wires in this post. Truth be known, very few wiresets available these days are solid core any more.
Most "supression core" wires are basically a string with carbon particles attatched, not metal wire anymore. Only thing that I see a "real" wire going to the plug would be on a Briggs n Stratton..
PostPosted: Fri Dec 10, 2004 4:13 am
I'd get a set of Acell 8.8mm race wires and cut them to fit. I love 'em in my truck. I was able to set my gap 0.010 higher than the factory setting and get MUCH better mileage and slightly better performance with 'em. I know MSD makes some good quality wires that you can cut to fit as well. You can also check www.magnecor.com I've heard nothing but good stuff about their wires.
Make absolutely sure you're careful with stripping the wire and when crimping it. The core is VERY easy to foul up. I almost ended up with one being too short because I screwed it up several times before getting it right. When I'm able to start working on some more cars, I'll be investing in a professional crimper. I've been told that the one MSD makes is pretty good. Pricey though...
PostPosted: Fri Dec 10, 2004 4:29 am
For the brief period of time the MSD Stacker on my truck's 6 cylinder worked, it was outstanding. Literally, it was so smooth at idle in gear (like when waiting at a light, etc.) that without looking at the tach, you couldn't tell if the engine was running. And the excelleration was way, way better. At the point where I'd hit 40MPH when leaving the base with the pedal floored, I would be at 65MPH with only moderate throttle with the MSD. The box didn't work long enough for me to get any indication of a change in mileage though :(
I think it was just a luck-of-the-draw defective unit though, so I don't fault MSD for it.
I should also add that my ignition was in excellent shape too. Fairly new Blaster 2 coil, brand new Acell wires, new Nippondenso plugs, and new cap & rotor. The only thing not new was the controller (or rather "ignitor" as Toyota calls it).
