It is currently Sun Nov 29, 2026 9:04 am
 Post subject: Carb tuning
PostPosted: Thu Dec 02, 2004 6:25 pm
I have never set a carb with a vac gauge before. Can someone give a brief synopsis of how this is done? Is the gauge connected to the carb? Manifold? What is optimum setting? Thanks all.
PostPosted: Thu Dec 02, 2004 6:52 pm
The vacuum gauge is connected to a source of manifold vacuum. If your carb doesn't have a manifold vacuum tap, the easiest location for one is the plug on the manifold branch that leads to cylinder #6. Remove the plug and find an NPT to hose barb adapter. Obviously, the hose barb size matches the hose attached to your vacuum gauge.
Typically, you set the idle speed with a tachometer. You use the vacuum gauge to set the idle mixture. The idle mixture screw is turned in or out to get the highest vacuum reading. Alternatively, you can skip the vacuum gauge and adjust the idle mixture to give you the highest and steadiest idle speed.
Frank
http://cars.rasoenterprises.com
PostPosted: Thu Dec 02, 2004 10:04 pm
http://www.centuryperformance.com/vacuum.asp
PostPosted: Mon Dec 06, 2004 6:03 pm
I have my gauge on the manifold. I'm showing about 24 inhg. It really was usefull setting the carb but I am curious. If normal is 17-20. Is Mo Better? Or is too much vacuum a bad thing. Sort of a dopey question I know.
Users browsing this forum: Google [Bot] and 18 guests
