| holley 390 questions https://slantsix.org/forum/viewtopic.php?t=11126 |
| Author: | guest [ Mon Dec 06, 2004 7:47 pm ] |
| Post subject: | holley 390 questions |
I have a mildly built slant 0.030" over, milled head, bowl work oversized valves, mp 460 cam, mp header and an offenhauser intake with a 600 holley. The combo runs great but the carb is a little too big. I've been looking to go to a 390 holley for a little while. Through a friend I found a double pumper 390 rebuilt ready to go for quite a good price. Is a double pumper a bad choice for driving a car mostly on the street or should I just keep looking and find a vacuum secondary 390? Does anyone run a 390 double pumper and what jetting, pumpcams etc. are you using? |
| Author: | Doctor Dodge [ Mon Dec 06, 2004 11:19 pm ] |
The problem with a mechanical secondary carb (double pump Holley) on a small displacement engine (Slant Six) is that the engine can not take all the CFMs at lower RPMs. Basically you will get a big bog if you stomp the carb wide open from idle or at low RPMs. DD |
| Author: | FrankRaso [ Tue Dec 07, 2004 6:43 am ] |
I think, for the street, vacuum or air-valve secondaries are the way to go. Mechanical secondaries are much better suited for the drag strip. Although new vacuum secondary 390s are quite expensive, you can probably find a used one much cheaper on eBay. Frank |
| Author: | Dennis Weaver [ Tue Dec 07, 2004 8:24 am ] |
CARTER! D/W |
