Couple more wiring questions
https://slantsix.org/forum/viewtopic.php?t=11129
Author:  textoad [ Tue Dec 07, 2004 8:49 am ]
Post subject:  Couple more wiring questions
'74 Plymouth Scamp, Automatic tranny.
First:
The stock alternator has two field connections. There is a blue and green wire that connect to these terminals. One on one side and the other on the other side. Does it matter which wire goes to which field terminal. On the schematic it looks like the field connections are each side of a coil so I suspect it doesn't matter.
Secondly:
The neutral safety switch has a three wire connector. I cannot tell which way it goes. How can I tell? Looks to me like it will go on two ways.
Thanks
Author:  SlantSixDan [ Tue Dec 07, 2004 12:15 pm ]
It does not matter which field wire goes to which field terminal.
Don't remember the NSS connection direction.
Author:  Craig [ Tue Dec 07, 2004 3:34 pm ]
Neutral safety switch.... it does not matter which way the connector goes on. The center pin is for the neutral safety start. The two outer pins are for the back-up lights.
Just put it on which ever way is most convenient.
Author:  textoad [ Tue Dec 07, 2004 10:01 pm ]
Craig, thanks. That's what I thought looking at the connector orientation and the schematic. I just needed to hear that before giving it the juice.
Thanks again.
