| Slant six distributor o ring https://slantsix.org/forum/viewtopic.php?t=11130 |
| Author: | golembieski [ Tue Dec 07, 2004 1:10 pm ] |
| Post subject: | Slant six distributor o ring |
What is the diameter of the oring that seals the distributor to the block. I don't have the dist with me and i am going to be around a lot of orings for the next 7 hours. Frank |
| Author: | Bob D [ Tue Dec 07, 2004 1:36 pm ] |
Distributor is 1 1/16" so an o-ring with a 1" ID would hang on nice and snug. Bob D |
| Author: | textoad [ Wed Dec 08, 2004 8:29 am ] |
Is it actually an o-ring that fits into a groove on the distributer shaft housing? Does it go beneath the hold down bracket or does it slide into the hole? I recently installed mine and there was an o-ring and a cork gasket in my gasket kit. I wasn't sure which one to use or possibly both. So I used the cork one which seemed to fit snug on the shaft housing and rests above the hole under the bracket. |
| Author: | golembieski [ Wed Dec 08, 2004 1:09 pm ] |
When i pulled the dist for my electronic setup all i found was the oring on the grove under the hold down. I tried to measure it but old rubber is not the best thing to measure. I guessed between 1-1 1/16 should get the job done so i got a hand full of each. Frank |
| Author: | Bob D [ Wed Dec 08, 2004 7:12 pm ] |
There should be two o-rings. One fits in a grove about 1/2" down on the distributor shaft and the other fits over the distributor shaft right under the adjuster plate that bolts to the bottom of the distributor. The one in the groove has a cross-section of about 1/16" while the other has a cross-section of about 1/8". Because the one in the grove is usually in place I assumed the latter one was the subject of the original post. Bob D |
