It is currently Sun Nov 29, 2026 12:59 am
PostPosted: Thu Dec 09, 2004 11:34 am
Grandson's 73 Dart is closer to being reliable transportation. Yesterday a friend came over and gave me a lesson on setting valves. The engine only has 58K on it, but had been sitting for a long while. Each time he adjusted a valve, the engine got quieter. Finally, I had to check and see if it was still running! He gave me some more tips, too. While replacing all the hoses, particularly those leading to the distributor and base of the carb, we found them to have sloppy fitment. Replaced a couple, and used clamps on the others. Man, nothing purrs like a tuned up slant!
Grandson wasn't as impressed with all our work, as he was with the new AM/FM/CD I had put in. The shop did such a great job that it truly looks like it came with the car.
Now we're waiting until just after Christmas when the new carpet gets here. I busted my you know what several times, slipping on the old vinyl crud when it contrinually broke up.
J.C. Whitney tells me the new seat covers won't be shipped until after Jan 1st. It is all coming together, but slowly.
Later in January, to the paint shop it goes.
PostPosted: Thu Dec 09, 2004 12:31 pm
While replacing all the hoses, particularly those leading to the distributor and base of the carb....
BASE OF THE CARBURETOR.....
I am suppose to have a place "at the base" of the carburetor to put some hoses into but don't ?. Explain what you have if you can? My truck is a 1987 3.7 (225) SS.
I have 2 3/8 inch. vacuum lines from a brake cannister #4227-010 which have no place to go. Manual says "under the base of carb". Pls. update my knowledge if you can.
Thanks
Larry
 Post subject: Hoses
PostPosted: Thu Dec 09, 2004 1:55 pm
My setup is probably completly different than yours. After all, it is a 73. As best I can recall, there was a small tube to the distributor for the vacuum advance, and a larger tube running to a cannister on the radiator brace. Drop by a dealer and ask or better yet, get a repair manual and examine it closely. Sorry I couldn't be of any help to you.
PostPosted: Fri Dec 10, 2004 6:30 am
Sounds like it's going along pretty smoothly. I sure wish my grandpa was still around to do some wrenching with me on my cars :(
Users browsing this forum: Amazon [Bot], Bing [Bot] and 10 guests
