misfire?
https://slantsix.org/forum/viewtopic.php?t=11151
Page 1 of 1
Author:  slnt6t4 [ Thu Dec 09, 2004 7:51 pm ]
Post subject:  misfire?
Hello- Just got registered on this site so bear with me as I am alittle confused. I have a issue with my 6 I hope someone can help me with.
my engine develops a miss at highway speeds, it doesn't backfire it just make a slight jerking motion. Here's what I've done to it. It's a 64 block with head and super six set-up off of a 77 volare. At first I was having problems devoloping vacuum so I replaced the carb with a reman bbd #6023 from early 70's 318. Also am using petronix electric ignition and removed ballast resister and went with internally resisted coil, plugs, wires, almost everything is new or rebuilt. Timing is set at 14degrees(comp cams said start at 8 and go up) Anyway I'm guessing I either have an ignition problem or a fuel problem!! HELP
Author:  Dennis Weaver [ Thu Dec 09, 2004 8:30 pm ]
...sounds to me like vacuum leak or timing is too advanced. What is your total timing?
D/W
Author:  63Dart [ Thu Dec 09, 2004 11:16 pm ]
My 63 misses under load. Same thing - jerking motion.
In my case, I know it's due to a bad cam lobe (old motor, #1 exhaust lobe worn down).
Just another possibility, if it's an old motor (but it does not sound like it is).
Author:  Bob D [ Fri Dec 10, 2004 5:49 am ]
Kevin,
I'm curious. How do you know that you have a bad cam lobe?
Bob D
Author:  dart63 [ Fri Dec 10, 2004 6:54 am ]
And if you do, isn't there enough rocker adjustment to compensate? Or does the extra travel throw the timng a little? Just curious.
Author:  63Dart [ Fri Dec 10, 2004 9:20 am ]
First time I watched the engine run with the rocker arm cover removed, I noticed that the #1 exhaust rocker was barely moving. Thought it was a bent pushrod - but it wasn't.
My theory is that the previous owner (who bought the car new and never sold it), became lax about changing oil and/or filling the oil. He was 93 when he died, but about my (mid-forties) age when he bought the car.
I know he was good in the beginning, because I have his "service coupon book" that shows that he changed the oil on regular basis. I actually owe that man a debt, because the car was in surprisingly good and original shape when I got it.
The lash is set correctly. I'm not much of an expert on this kind of theory - but I *think* that the only way to compensate for less lift in a case like this would be to have a rocker arm with different geometry.
I'm fixing to rebuild the engine soon - so I'm actually excited in a perverse kind of way to see what the cam looks like. If the lobe is half worn down, it's just another example of how bullet-proof these engines are.
Even more amazing is that except under medium/heavy load, the engine runs like a top, and I still get about 17 MPG (maybe a little more or less now that I have the offy two carb set up).
AND - it's been this way since I got the car 4 years and 18,000 miles ago!
The longer I have this car, the more amazed I am at the /6 motor. In fact, when I first got the car, I was a little bummed that it "only" had a /6 (I'd always driven 318's).
But now I love that motor, and I'm proud to say its got a slant. And I always get the same comment back: "it'll run forever."
Author:  SlantSixDan [ Fri Dec 10, 2004 9:39 am ]
A surging effect at highway road loads often indicates a lean mixture -- check your carburetor float level carefully. Also remember that the V8 BBDs and the Slant-6 BBDs are calibrated differently and some of the differences can be difficult to finesse out. (It's not just a question of larger/smaller, but of *different* calibrations).
Also review the specs on that Pertronix Ignitor and the internally-resisted coil you installed. It's possible you picked a coil with too much resistance. Me, I don't like internal-resistor coils, because they run hotter than coils without inbuilt resistors. I also don't mess with Pertronix Ignitors 'cause the genuine Chrysler electronic setup is good and inexpensive (and parts are so universally available).
Author:  Dennis Weaver [ Fri Dec 10, 2004 9:42 am ]
I, too, like Chrysler Electronic, but you just can't beat the Pertronix for cost effectiveness and ease of installation.
D/W
Author:  SlantSixDan [ Fri Dec 10, 2004 9:43 am ]
That is true, I'll certainly grant you that. And, you get to keep your factory timing curves, which can be difficult to do when swapping distributors.
Author:  dart63 [ Fri Dec 10, 2004 10:22 am ]
I'm with Dan on this one, surging is probably more common in lean burn set-ups, just a slight sensor error, or bad engine computer connection somewhere would send the damn things running lean and they would "Push and Pull" at highway speeds.
The only way that can happen on a 63/64 product is carb or vacuum troubles. If it were plain old power loss at load I would be more likely to suspect timing.....
Also, the Pertronix ignitor I once had on my 63 before going to Chrysler electronic wore out the tape on the rotor...and one tiny magnet escaped and caused me to almost pull my hair out finding the trouble......but this resulted in rough idle condition, not surging. Good luck.
Kevin
Author:  Dennis Weaver [ Fri Dec 10, 2004 1:06 pm ]
Kevin
I'm sure you knew this, but there's supposed to be an air gap between the magnet wheel and the pickup. One thing I like to do with the pertronix is shim the little plastic tube into the magnet wheel and put a couple dabs of good ole JBkwik where the rotor and the magnet wheel meet to firm everything up real good and ensure the most accurate timing possible. The as-delivered Pertronix leaves a little to be desired as far as slop between the shaft and the magnet wheel.
Also, overly "hot" timing can most definitely lead to surging at cruise (high vacuum) even if the car is running great otherwise and not pinging, particularly in low-compression engines. That and a vacuum leak are the first things I'd look for in this situation. Then I'd start looking for other causes of a lean condition.
D/W
Author:  SlantSixDan [ Fri Dec 10, 2004 1:11 pm ]
Yep, timing can definitely affect things in strange ways. At one time, the vacuum advance in my '65 Valiant w/225 blew its diaphragm, so I swapped on the only spare I had handy, from a '61 170. The car ran fine *except* at fast idle in Neutral or Park, when it would sputter and misfire badly. That particular vacuum advance, combined with whatever I had the base timing set at, was too much with no load, and the misfiring was caused by the spark randomly jumping ahead to the next cylinder. Disconnecting the vacuum advance made the misfire go away, and resetting the base timing and installing a different vacuum advance fixed the problem permanently.
Then there was the time I set the float too low in the same car; it ran fine except if I kicked down into 2nd to pass somebody on the highway. Surge! Surge! Surge! Surge! The too-low float level meant not enough gas in the carburetor, and the engine was drinking it dry.
Author:  kesteb [ Fri Dec 10, 2004 4:07 pm ]
Nice ramble guys, but you didn't tell him what to do.
A rebuilt carb is almost always set incorectly. First check the float level. Make sure it is right. A rebuild kit or a repair manual will have the correct setting.
Take a test drive. Did this fix the problem?
I would then check the spark plugs. You will be looking for a nice even tan color on all of the plugs. If there not, then you may have to adjust the "power" piston. This controls the metering rods. They may not be set correctly. I currently have mine set at 25/64s. My \6 is stock with a 318 BBD. You will need to experment with your car to see what is correct for you.
Next, the 14* BTDC is a little to much. I would suggest backing that down to 8* to 10*. The only way to really know what to set the initial advance is to take the distributor apart and see what it says on the governor. Mine has a "9R". This means there is 18* of certifigual advance built into the distributor. My engine runs best with 6* initial for a total of 24* total mechanical.
If not, come back and we will have more susgestions.
Author:  Dennis Weaver [ Fri Dec 10, 2004 5:49 pm ]
Coulda fooled me...
A surging effect at highway road loads often indicates a lean mixture -- check your carburetor float level carefully....Also review the specs on that Pertronix Ignitor and the internally-resisted coil you installed. It's possible you picked a coil with too much resistance.
Then later
....That (timing check) and a vacuum leak are the first things I'd look for in this situation. Then I'd start looking for other causes of a lean condition.
and several others have offered suggestions. Just because nobody gave a step by step hand holding like you did doesn't mean slnt6t4 wasn't guided in the right direction or given some ideas where to start.
D/W
Author:  70valiant [ Fri Dec 10, 2004 6:08 pm ]
you guys are all talking about fixing a surging problem BUT he describes it as a miss. I would check and see if the metering rods are to high. When I was tuning a 318 BBD I had a high speed miss caused by an overly rich condition.
