| My first Slant six https://slantsix.org/forum/viewtopic.php?t=11152 |
| Author: | moparDuster [ Thu Dec 09, 2004 10:32 pm ] |
| Post subject: | My first Slant six |
Got myself a 73 duster with a 225. Shes old and not the good looker but man did she run good until i got my hands on her. First thing i did was pull out the smog equipment put on a cherry bomb muffler on a "friends doing, not mine". it still ran good but a little on the hot side, did a flush out and ran a little better. now heres where i choked her, changed the air filter and took off the aftermarket air conditioner, "who needs to be cool in a hot rod, thats what windows and vent boxs are for" changed out the autolite plugs for Champion & new wires. i was tring to put in a new temp gauge sending unit and snap... to tight, i was able to drill it out and tap it now a got a little coolant leak. I got an oil leak. i have a gauge on and am running around 45psi i've done what i know of changed vavle cover gasket, tightened down the alternater bracket today and tightened the timing chain cover bolts, they felt a little loose. what else could i look for to stop the oil leak? Thanks to every one on the forums i learned alot when i'm not sure about something i go to the Haynes book or here. You guys rock |
| Author: | FrankRaso [ Fri Dec 10, 2004 7:14 am ] |
Oil leaks can be hard to find, especially when the entire engine is covered in oil. If you already tightened all of the obvious gaskets, I think you are going to have give the engine a good wash and look for leaks on a clean engine. I have a similar problem and gave my engine an engine shampoo at the local car wash. I have been using about a quart of oil with every fill up on my 73 Dart. I discovered that there were no leaks coming from the gaskets so I had to keep looking. Even by putting the car up on blocks and looking for leaks while the engine was running didn't show any obvious sources of oil drips. However, I discovered that the front seal area was wet with oil. I will be installing a new front seal repair kit today (along with a new timing chain set since everything will be apart) that includes a stainless steel sleeve to eliminate any groove the seal may have cut into the crankshaft. In case you have the same problem, Felpro has a front seal repair kit. Napa lists a Victor kit which has been discontinued. They put a kit together for me and the Chicago Rawhide crankshaft sleeve that Napa supplies seems to be a better design than the Felpro sleeve. I've got both now and will install the one that will work better. Frank |
| Author: | dart63 [ Fri Dec 10, 2004 7:21 am ] |
It probably is seals like Frank points out. The leaks from seals can be hard to find because the oil isn't always present exactly where it leaks from. Also, get a fresh valve cover gasket after you wash her and remember to tighten the valve cover down to factory specs and start in the center bolts and work your way forward and back from there so you are actually squeezing the valve cover down from the inside bolt out just like you would tighten a manifold. Good luck and congrats......and remember 'If it ain't broke, don't fix it"... |
| Author: | moparDuster [ Tue Dec 14, 2004 2:24 am ] |
well the oil leaks have seem to go away. but know i have a nother problem after changing the spark plugs it know hastates when it get warmed up and when i slow down too fast it dies and has a hard time starting up again. I know i have a vacuum leak but i never had this problem before i changed the plugs. |
