It is currently Sat Nov 28, 2026 7:08 pm
PostPosted: Thu Dec 02, 2004 12:51 am
Hi guys....i have a 1987 ram 150 van sl/6 automatic tranny.
When it runs it runs good....the problem that i'm having is a bit frustrating, because of it's inconsistency.
I could be stopped at a set of traffic light and the engine idles perfect, then i stop on the next traffic lights and i have to use my left foot to hold the brake so i can increase the rpm's with the right foot to keep it from stalling(mostly in neutral).
Today i started it up after it's been sitting for couple of days and the rpm's would alternate slowly up and down almost to the point of stalling and the longer it went on.. the faster the rpm alternations until it stalled.
I noticed that when i punch the gas pedal and rev it for a while and then let go....it idles perfect for about 20 seconds before it starts struggling again.
Could anyone please give me some idea as for what could be wrong with my slant?
PostPosted: Thu Dec 02, 2004 5:08 am
Contributor
If the engine is flooded after it stops, I would suspect a bad float or needle valve.
 Post subject: weak
PostPosted: Fri Dec 03, 2004 9:54 pm
well just try out the ol' idle screw and see what that does.
PostPosted: Sat Dec 04, 2004 10:28 am
could be a bunch of silly things or just one big crap :roll:
maybe:
bad valvle lash (especially intake) too tight would give you headache
vacuum leak (try to find out spraying the carb and near the carb or near the intake head ports with butane. If it revs up, you finded your problem)
retarded timing
rusted and blocked mechanical advance in the distributer
blown vacuum pod on dist.
about the big issue, I'd rather not mention any big trouble. IO prefer to believe that's only minor things.
good luck, happy weekend.
Juan Ignacio Caino
PostPosted: Thu Dec 09, 2004 8:41 pm
Can people who have the Slant Six set up in an 1980-1988 truck send some photos of their engine compartments my way:
-carburetor set-up (linkages, springs, vacuums, etc.)
-vacuum lines from EVAP charcoal canister
Thanks for anything you're willing to do.
PostPosted: Fri Dec 10, 2004 6:56 pm
Tighten the nuts that hold the carburetor to the manifold.
Every once in a while mine will idle ok, then when I lightly touch the acelerator pedal to drive off the engine will almost die out, but under heavier throttle it is ok. I found those nuts loose. What was happening is at curb idle the manifold vacuum held the carburetor down, then as I lightly touched the throttle, the cable pulled the carb sideways and lifted it up off the gasket on one side (creating vacuum leak) because the nuts were loose.
PostPosted: Fri Dec 10, 2004 9:14 pm
Try replacing the PVC valve. When they get old and gunked up they can act like this. In a pinch you can clean one out with carb cleaner. Also make sure the hose to it isn't collapsing while the engine is running.
Former bent 6 owner
Mark
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
