Hall effect?
https://slantsix.org/forum/viewtopic.php?t=11158
Author:  Jopapa [ Fri Dec 10, 2004 11:50 am ]
Post subject:  Hall effect?
I noticed on pretty much all the Mallory ignition controllers that they're not compatible with hall effect triggers. Also I noticed that the Pertronix points eliminators use a hall effect system. What exactly is hall effect, and why would some ignition boxes not like it?
Author:  Dennis Weaver [ Fri Dec 10, 2004 1:12 pm ]
I can't tell you how it works (but I can think of a couple people who likely can and will :) ), but I can tell you that a pertronix is a hall effect trigger and also later model Chryslers came with Hall effect distributors (late 80's).
D/W
EDIT: Duh, there's an echo in here - I reread and saw you already knew about the Pertronix... :oops:
Author:  kesteb [ Fri Dec 10, 2004 4:13 pm ]
The differance is a Halls Effect produces a square wave and a VR produces a sine wave. The VR will need additional circuits to modify the wave form to a square wave. The Mallory most likely dosen't have those circuits. One way to flatten the VR sine wave is to use the 4 pin GM HEI chip for the ignition controller as apposed to stock mopar.
Author:  Jopapa [ Sun Dec 12, 2004 5:35 am ]
Interesting. Is there anything similar to the Pertronix that isn't a Hall effect trigger?
Author:  Dennis Weaver [ Sun Dec 12, 2004 9:51 am ]
A Mopar electronic distributor.
D/W
Author:  Pierre [ Sun Dec 12, 2004 1:19 pm ]
Time to get engineering-geeky.
The hall effect.... If you create a magnetic field around a conductor, you will induce an electric field and current. The same goes the other way around. Thats how your alternator works. The magnetic field pushes the charged particles to one side of the conductor, leaving the other side of the conductor with a lack of charged particles. This seperation of the charged particles, as Edwin Hall discoverd, can be significant enough to create a voltage.
Translation to something more useful in this case: In a sensor where the magnetic field keeps getting repeatedly broken, a sinusoidal (AC) current will be observed passing through the conductor.
Thats why you need diodes in your alternator to flatten it out and charge your battery, or else for every amount of charge you put into your battery you will be taking it right back out.
Author:  Guest [ Sun Dec 12, 2004 4:46 pm ]
So, dare I ask why a hall effect distributor might be used over a normal one. At one point I was looking at a Chrysler 3.0 liter FI setup from a van till I realized the van used a hall effect trigger and probably wouldn't easily work with the slant. Since it doesn't seem like a lot of vehickles use the hall effect is it actually better in any way?
-Shivadart
Author:  Pierre [ Sun Dec 12, 2004 5:49 pm ]
The advantage would be that the EI/halleffect triggers don't wear out like points do. Points, when used in stock form, have higher currents going through them. After repeated opening/closing action with this current, they wear out.
Regarding your 3.0L van setup, if you want to use this system on your slant, check out the distributor sensor carefully. Some may give one pulse per plug fire, some one pulse per cam revolution. If its one pulse per cam revolution it will most likely use a crank sensor as well. If you only want one pulse out of your slant EI distributor you can file down the other 5 points on the reluctor.
Author:  Guest [ Sun Dec 12, 2004 11:13 pm ]
I scrapped the 3.0 liter idea and decided to try Bob's system. I was actually talking about the advantages of a regular EI distributor and a EI hall effect trigger. Right now I'm running MSD, I'm just curious why the hall effect wasn't used more often before they got rid of the distributor.
-Shivadart
Author:  Pierre [ Mon Dec 13, 2004 2:27 am ]
The stock EI distributor is magnetic, thats why you have to use brass feeler gauges (brass isn't magnetic) to set the gap or else you can never get a proper feel when doing so.
It is my understanding that "hall effect" is a term applied to any sensor that is based on magnetics. Could be wrong on that though.
You can use an msd (at least their 6a line) with points, a crank trigger, or the stock mopar EI distributor.
Author:  Dennis Weaver [ Mon Dec 13, 2004 7:55 am ]
pierre, I'm definitely no electronics expert, but I'm pretty sure the stock EI distributor is NOT a hall effect type. One reason I say that is that Chrysler went to a hall effect distributor in the late eighties. My '88 truck is equipped with one, and it is completely different than a traditional EI distributor.
I'm going to take a stab at something I only have a rudimentary understanding of, so forgive me... As I understand, the Hall effect involves moving magnets (magnetic fields) in front of a special IC such that the changing field switches a circuit on and off. With a standard Chrysler IE, on the other hand, a finned ferrous wheel moves in proximity to a magnetic field which is wound with a small current passing thru, disturbing the field, which causes a varied resistance in the winding. The resulting current fluctuation is converted and amplified by the control box into an on/off switching current to the coil.
I hope I am at least close with that description, and did not step on any EE or electronics experts' toes in the process. ;) :lol:
D/W
Author:  Pierre [ Mon Dec 13, 2004 1:50 pm ]
Dennis, in a standard EI distributor is the reluctor itself a magnet? I think its just a hunk of steel. I do know for sure though that there is a permanent magnet in the black oval pickup part though.
I think you may be on to something though, hall effect could mean that a permanent magnet is moving while the older style means that an electrically induced magnetic field is alterd by a moving reluctor. Either way, its still all magnetic no matter which end of the stick you look at it from ;)
Your explanation is fine. The pulse of current coming from the distributor fires off a transistor (the oval piece on the outside of the EI box mounted on a heatsink usually) and this inturn pulses the coil with voltage from the balast.
Similar in the way a speaker works. Try putting an ohm-meter across a speaker, then gently moving the cone by hand. Many people will freak out and think its broken because the resistance is changing.
Author:  Dennis Weaver [ Mon Dec 13, 2004 3:56 pm ]
I think the difference has to do with the square waves vs. the sine waves that kesteb mentioned earlier. I'm deducing that a square wave would be an on/off type of deal.
D/W
Author:  Dennis Weaver [ Mon Dec 13, 2004 4:00 pm ]
Nope. Just a piece of steel.
