| Welding bung on header while it is still on car https://slantsix.org/forum/viewtopic.php?t=11160 |
| Author: | Pierre [ Fri Dec 10, 2004 6:18 pm ] |
| Post subject: | Welding bung on header while it is still on car |
Does anyone see a problem with this? I want to weld an o2 bung on my clifford shorty header but don't want to take it off the car. The collector gasket I don't care about, but I didn't know if I should be worried about the gasket mating it to the head. |
| Author: | slantzilla [ Fri Dec 10, 2004 8:41 pm ] |
If you can, run the car so the header is warm before you weld it. That way it will cool off a lot more evenly. |
| Author: | Pierre [ Fri Dec 10, 2004 8:55 pm ] |
Thats a good idea. I don't plan on doing the welding myself, I'm going to take it to a muffler shop and have them do it. The last one they did for me on the tailpipe was $20 so I'd rather do that then make a welding boo-boo. |
| Author: | Guest [ Fri Dec 10, 2004 9:50 pm ] |
Also, most welding shops will use a stick welder which has a larger heat effected zone and a longer heat up and cool down time. this makes the weld more pliable and less likely to crack under vibration or expansion and deflation. Mig welding will make a strong but brittle weld which isn't ideal for the exhaust. |
| Author: | 72Duster [ Mon Dec 13, 2004 1:19 am ] |
Disconnect the battery when welding. |
| Author: | Doctor Dodge [ Mon Dec 13, 2004 10:22 am ] |
Quote: Disconnect the battery when welding.
Also disconnect / isolate any electronic ignition box you may have.MSD says to do this if you use any type of electric welder, anywhere on the car. DD |
