Oil Redux
https://slantsix.org/forum/viewtopic.php?t=11161
Author:  63Dart [ Sat Dec 11, 2004 3:43 am ]
Post subject:  Oil Redux
I'm getting ready to rebuild my slant - pretty much stock, except for a cam, some bolt ons, and some head work.
I live in Nor-Cal - so the weather runs from about 40-90 degrees (F), depending on whether Summer or Winter (rest of time it's around 55-65).
I intend to use the car as a driver, and won't be doing any racing, etc.. Probably 1/2 time city and 1/2 time freeway...
What oil should I use???
I'm thinking 10-40 GTX for first two oil changes, and Mobil 1 15W-50 after break-in.
I'm using Mobil one in my V-6 Ram truck, and it seems to work well . . . but I'm open to other suggestions.
Author:  Dennis Weaver [ Sat Dec 11, 2004 8:12 am ]
I stick with good old Valvoline SAE 30 in all my older drivers (warm climate here), but I doubt you'll find many others that do the same. There are obvious differences in viscosity, and some differences in quality, but like anything, 70% of the difference in oil is marketing and hype (in my humble opinion, of course ;) )
I do experiment with different oils in my "race" six, I've settled on a blend (3:2) of 0W-30 synthetic and Valvoline 10W30. Only reason I bring it up is that I drive it VERY hard, and no problems in 10 years and scores of full-blast 1/4 mile passes. Moral of the story is, you can do with most any oil in a slant six as long as you keep it changed and keep everything maintained and don't fill it up with "molasses" in the cold... :lol:
D/W
Author:  Pierre [ Sat Dec 11, 2004 1:02 pm ]
Haven't been to Oakland in ages, last time I can remember going there was in the 5th grade field trip to watch the A's play!
After the inital 10w-30dino oil change I also went to 15w-50 Mobil 1 synthetic with the taller wix filter (51773) and a standpipe. Pressure as soon as I let go of the key, maybe a split second after, hot or cold. I chose 15-50 because I recall reading that when comparing dino to synthetic viscosities, you have to go one step higher numerically to get roughly the same thing. Remember synthetic also holds its viscosity over a wider temerpature range then dino.
