What is a manual valvebody?
https://slantsix.org/forum/viewtopic.php?t=11194
Author:  slanter6 [ Tue Dec 14, 2004 5:08 pm ]
Post subject:  What is a manual valvebody?
does the trans still shift by itself or do you have to make it shift?
Author:  Dennis Weaver [ Tue Dec 14, 2004 7:39 pm ]
It's just what it sez... manual. You gotta shift the gears. If you put it in "1" it is in first. If you put it in "2", it is in second, meaning it will even take off in second. If you put it in "D", it's in third till you take it out of third. That means if you forget, you start off in third. Also, the ones I've seen negate any kind of OEM engineered "lockout" safety feature, meaning if you inadvertently put it in "1" at 90 mph, it tries to go into first @ 90!!! :shock: This usually results in an explosion since certain transmission internals rotate at many times engine speed.
D/W
Author:  slantzilla [ Wed Dec 15, 2004 12:21 pm ]
My Cheetah does not have low band apply. You can put it in low at speed and as long as you don't get on the gas it will freewheel. It is also a reverse pattern. D=1, 2=2, and L=3.
Any manual valve body that has low band apply will do bad things if you stuff it in low at speed. :shock:
Author:  Dennis Weaver [ Wed Dec 15, 2004 1:11 pm ]
That makes sense... It's using the overrunning clutch. I saw one once where the car did have low-band apply in first - went into low by mistake once, the band tried to weld itself to the drum and "KABOOM!!!" 727 shrapnel everywhere!
