| yeah more rear end questions, posi? od? https://slantsix.org/forum/viewtopic.php?t=11208 |
| Author: | stinky mctinkerpants [ Wed Dec 15, 2004 10:27 pm ] |
| Post subject: | yeah more rear end questions, posi? od? |
I am doing the swap in my dart, i can spot an 8-1/4 but how can i tell if its posi? did they ever have od and will one from a different body like an m or j fit. all i really need is a 8.25 unless a 8.75 falls in front of me. also is there anything besides the usual i should look for to replace on these since i have it off? i am going to spend the holidays doing some renovations on the old sled. |
| Author: | Rust collector [ Thu Dec 16, 2004 4:37 am ] |
The rear from an f-body is about 3" wider than an a-body. I have this in my 67valiant, and it vorks ok, but you have to use a lot of offset in the wheels, or use stock wheels and narrow tires. I use stock aspen wheels, and 185 70/14. They rub slightly in curves, when i have a lot of stuff in the trunk. |
