| Floppy side mirror fix? https://slantsix.org/forum/viewtopic.php?t=11210 |
| Author: | NewLancerMan [ Thu Dec 16, 2004 9:13 am ] |
| Post subject: | Floppy side mirror fix? |
Next on the problem list: my mirror! I have a nice driver's side mirror on my 62 Lancer that has too much play in it. it basically flops down and is useless. I was told that its possible to try and use a small punch to put a indentation in the ball of the mirror that would hold it in place? Or do you pinch the housing down on the ball? Anyone have any suggestions as to a fix? I'd hate to replace the otherwise very very nice mirror. I have some pictures of it here: My flopppy mirror Thanks again |
| Author: | VDART [ Thu Dec 16, 2004 7:01 pm ] |
| Post subject: | MIRROR repair |
take the glass out of the front, it should have a thin metal ring that holds it in place, once this is out you will see the pivot area, you might get lucky & just tighten up the screws holding the pivot, otherwise that would be the area you dimple/punch to take the slop out. Enjoy your ride!!!!!! |
| Author: | NewLancerMan [ Thu Dec 16, 2004 7:51 pm ] |
i'll give it a try and see what I can do! thanks! |
