| Okay,Guys need help Please!? https://slantsix.org/forum/viewtopic.php?t=11232 |
| Author: | Guest [ Sat Dec 18, 2004 12:19 pm ] |
| Post subject: | Okay,Guys need help Please!? |
when I turn the key to the "start" position the engine starts/runs as soon as i let go of the key "on" position the engine cut out/dies. if i hold the key to the crank/start it stay running.???? this is on a fresh rebuld with the lean burn system removed. and orange box ECU and 1997 rebuilt DIST. my brain hurts from all this trouble shooting thanks in advance |
| Author: | Bob D [ Sat Dec 18, 2004 12:50 pm ] |
The problem is your ballast resistor. Bob D |
| Author: | Guest [ Sat Dec 18, 2004 2:12 pm ] |
Quote: The problem is your ballast resistor.
thats what i was thinking so,,,,i used the coil from the lean burn and by-passed the ballast and ran a jumper wire to the + side of the coil.Bob D no change!!??? Paul |
| Author: | Guest [ Sat Dec 18, 2004 2:13 pm ] |
btw the 1979 dist. not 97 but,,,you knew that |
| Author: | Guest [ Sat Dec 18, 2004 2:14 pm ] |
Quote: Quote: The problem is your ballast resistor.
thats what i was thinking so,,,,i used the coil from the lean burn and by-passed the ballast and ran a jumper wire from the + of the battery to the + side of the coil.Bob D no change!!??? Paul |
