It is currently Thu Nov 26, 2026 7:22 pm
 Post subject: intake /exhaust gasket
PostPosted: Wed Jan 05, 2005 10:59 am
what is the best intake/exhaust gasket for use with an aluminum intake and headers....what about dead soft copper or aluminum? would the intake manifold seal with a custom gasket from either of these previously mentioned materials?many thanx in advance...
there is only one...
PostPosted: Wed Jan 05, 2005 2:03 pm
I like & use Mr. Gasket PN 320G. Nice, thick gasket that rids you of the headache of trying to get the headers to seal properly to the head.
-S/6
 Post subject: where from?
PostPosted: Wed Jan 05, 2005 4:09 pm
where do you find the gaskets at, summit? do you remember how they cost?
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Wed Jan 05, 2005 4:49 pm
Here it is on Summit. They list it at a little under $16.
I simply order mine through my local NAPA. After shipping (to Alaska mind you) I get them for about $20.
-S/6
PostPosted: Wed Jan 05, 2005 4:51 pm
Never had a problem with the Fel pro gaskets, I have the Offy 4bbl intake and the Clifford duals, zero leaks.
PostPosted: Wed Jan 05, 2005 6:47 pm
SSRN National Champion
Cox Bros in Columbus Ohio 614-268-9920
put one of there gaskets on in 2002 ran all year took it off that engine put on my racing engine and have took the intake/exhust off three times and there good to go. Extra thick about a 1/4 thick and that dog will hunt. Not that pricey.
When it works doint screw it up. Thanks Ron Parker
Hell Hath No Wrath Than A Possum Scorned
