Ok, where is the oil pressure sending unit?
https://slantsix.org/forum/viewtopic.php?t=11323
Page 1 of 1
Author:  G-bob [ Sat Jan 01, 2005 4:59 pm ]
Post subject:  Ok, where is the oil pressure sending unit?
Put the water temp sending unit on my neighbor's slant and it hit me that I couldn't recall installing the oil pressure sending unit. I've looked all over (at least where I can see with the header, intake, carb, a/c comp, p/s pump, and other stuff on there now).
Just where is it on a 225? I've been through my 67 service manual, but it doesn't show it anywhere.
Author:  Jeb [ Sat Jan 01, 2005 5:24 pm ]
It is just below the oil filter on the filter mounting point. Kind of hard to miss it if you get under the car and look up.
Author:  G-bob [ Sat Jan 01, 2005 5:26 pm ]
Thanks.
Author:  G-bob [ Sat Jan 15, 2005 11:45 am ]
Ok, so the pressure sending unit is actually on the oil pump, and not the block itself, right?
The new oil pump has a bolt coming out of the "point" that is just below the filter mounting pad. The bolt is replaced with the sending unit, correct?
Author:  SlantSixDan [ Sat Jan 15, 2005 12:01 pm ]
Correct.
