| up shifting https://slantsix.org/forum/viewtopic.php?t=11346 |
| Author: | Guest [ Tue Jan 04, 2005 11:25 am ] |
| Post subject: | up shifting |
does my kickdown linkage need a return spring? the lever on the tranny goes all the way back @WOT. but does not return? kinda sticks all the way back. it kicksdown to 1st then to 2nd but does not up shift back to 3rd(drive). |
| Author: | Guest [ Tue Jan 04, 2005 11:32 am ] |
nevermind id say this anwser my question http://www.slantsix.org/forum/viewtopic.php?t=11250 |
| Author: | Super6 [ Tue Jan 04, 2005 11:44 am ] |
I installed a spring on the trans lever on my truck because the lever was "lazy" in returning to light pressure (I am using a Lokar KD cable). The trans lever will come back immediately now, but the spring on the trans end does increase the effort to press the accelerator down. Adding a spring at the trans is essentially the same as adding an additonal spring to the throttle linkage at the carb (with the cable KD at least). -S/6 |
