| head milling https://slantsix.org/forum/viewtopic.php?t=11421 |
| Author: | Guest [ Tue Jan 11, 2005 7:22 pm ] |
| Post subject: | head milling |
I have a hydraulic lifter slant 6 (1983) and was wondering if I have to get shorter push rods if I milled the head 0.100"? The rockers are not adjustable. |
| Author: | Doctor Dodge [ Tue Jan 11, 2005 9:22 pm ] |
I would say yes. Shorter pushrods or shim-up the rocker arm assembly. The best deal would be to have adjustable push rods but I don't know of any that allow the oil flow thru the pushrod while being long enough. The best way to "set" the hydrualic lifter is to give it just a little "preload", enough to take-up the clearance and keep things quite but not a lot, so they don't 'pump-up' and hang the valves open at high RPMs. DD |
